Myth or Fact - Air Tanks?
15 years 1 month ago #7745
AtkiPete
GuddayM8
'Az I no it'
I aint seen no truck without trailer control handle
May B sum odd spots to mount it
unless it's specd up for rigid only
most yanky type trucks have a proportinin valve th@ regulates something like 60% of brakeing to primover n 40% to trailer on each jab of the brake foot pedal
to check trailer with tug test jist idle along in 1st n pull out (or is it in on new gear) trailer control doo wacky, normally the pritty colored button on the dash or where ever
also most trailers have maxi type spring brakes on axles nowasdayz
also sum weird plumbin on new gear as the truck parking brake button has to B charged to get trailer control button to release said trailer brakes
ButEyeDo................................
[ch9787]
Replied by Swishy on topic Re: Myth or Fact - Air Tanks?
AtkiPete
GuddayM8
'Az I no it'
[ch9787]
15 years 1 month ago #7746
by atkipete
Replied by atkipete on topic Re: Myth or Fact - Air Tanks?
Swishy ,Dunno about the Yankee trucks, they used to have the black tap, red tap and Yellow tap, then the little control wheel plus the handle. Pity if you were colourblind.
I have driven a lot of Volvos and they have recently got rid of the trailer brake handle on the prime movers. They have disc brakes on the prime mover and probably designed to be hooked up to a new trailer with discs and ABS.
15 years 2 weeks ago #7747
by huppypuppy
Most European trucks today have Electronic Braking Systems (or EBS) which replaces mechanical service application with electronics for actuation of the air circuit!
Joe
Replied by huppypuppy on topic Re: Myth or Fact - Air Tanks?
Pete,Swishy ,Dunno about the Yankee trucks, they used to have the black tap, red tap and Yellow tap, then the little control wheel plus the handle. Pity if you were colourblind.
Joe
Time to create page: 0.376 seconds
