- Thank you received: 50
Kenworth/VDO speedo LCD odometer display
13 years 1 week ago #108777
by tim
Kenworth/VDO speedo LCD odometer display was created by tim
A few months ago the LCD( Liquid Crystal Display) odometer display started to play up with the display flashing, disappearing, then it would be fine for a while & then it began to disappear for longer periods until it stopped working altogether.Needing to be able to fill out a National Driver Work Diary for a couple of runs soon I figured it needed my undivided attention soon. I was in contact with a gent in South Australia who described all my symptoms to a tee, he then said the magic words"send me some money & I'll send you the fix" Well I sent the loot & waited a few days & along came a cd mailer package in the post. Opened it up, there was a DVD & an LCD. Watched the Dvd, removed the speedo from the dash & dismantled it as per the Dvd, removed the LCD, installed the new one, reassembled the speedo as instructed, refitted the speedo, hooked up the wiring, turned the ignition on & wowee, it worked. The Odometer showing the correct mileage reading too. Time taken for the fix was about 30 minutes. Cost of the LCD & the DVD, including postage was $90 dollars. Not sure what other trucks use the electronic VDO speedo & if they suffer from the same problems but thought it may be of interest to others. Dexterious fingers would be helpful, don't need the bull at a gate feeling. If anyone's interested i can give you the gent's phone number. Cheers Tim
13 years 1 week ago - 13 years 1 week ago #108778
by werkhorse
Replied by werkhorse on topic Re: Kenworth/VDO speedo LCD odometer display
The kw LCD displays have a habit of doing that and our man here in town said it is more likely to happen the more you have your dash lights on .... Something to do with the heat drying the joints/connections out.
Had both the bosses SAR and the 104 done .....oh and the Speedo remembers the milage even if the display don't show it
Last edit: 13 years 1 week ago by werkhorse.
13 years 1 week ago - 13 years 1 week ago #108779
Replied by on topic Re: Kenworth/VDO speedo LCD odometer display
Timmy
Well done now you will know how far over the speed limit you are or how far from woop woop you are. LOL
Trevor
Trevor
13 years 5 days ago #108780
by paul404
Replied by paul404 on topic Re: Kenworth/VDO speedo LCD odometer display
Gday Tim, i would like to know more about this as the fleet i work for has heaps of odometers and hour meters fading in and out.
Thanks paul
Thanks paul
13 years 1 day ago #108781
by tim
Replied by tim on topic Re: Kenworth/VDO speedo LCD odometer display
Hi Paul, I'll pm you with the guys phone number & hopefully he will be able to help you out. Cheers Tim
13 years 1 day ago #108782
by paul404
Thanks Tim
13 years 1 day ago #108783
by Middleton Diesel
Replied by Middleton Diesel on topic Re: Kenworth/VDO speedo LCD odometer display
weve had that drama a lot lately but have found it happens with damper weather. ever since its been raining buckets up here in Qld a few of my customers have had this drama with their kenworths. Theres a mob in Toowoomba that replaces the LCD for the same $90
8 years 9 months ago #183307
by Brainsmoke
Replied by Brainsmoke on topic Kenworth/VDO speedo LCD odometer display
Hey Tim, I see this post away back . Do you remember if the DVD was necessary ... I ordered a new LCD but get the feeling its not a straightforward fit?
8 years 9 months ago #183561
by Brainsmoke
Anyone else able to shed any light on the procedure to fit an LCD?
8 years 9 months ago #183611
by shiney005
Replied by shiney005 on topic Kenworth/VDO speedo LCD odometer display
The same thing is happening to the VDO speedo in my Inter. Do you order an LCD from VDO or are they a generic item?
Time to create page: 0.290 seconds
