- Thank you received: 43
Spin on oil filters for International 6-281
3 years 1 month ago #220247
by Merrick
Spin on oil filters for International 6-281 was created by Merrick
Hi all, it's been a while.
About 6 months ago, the oil filter canister on my C1200 started leaking. If you've had a leaking one, you know I'm not talking some drips here and there, it really starts pouring out around the lip.
Tried new seals, gasket sealant, all sorts with varying and usually temporary success. Currently it seems ok, but I have to check every time I start it to make sure, which is getting wearisome.
I was talking on FB today and someone mentioned they used a spin on filter on their 281. Is there an adaptor you can buy? Or was this factory for late ones (maybe D lines?)
One of those would be very helpful.
3 years 1 month ago - 3 years 1 month ago #220248
Replied by Swishy on topic Spin on oil filters for International 6-281
Merrick
gudday m8
in the filter box is there 2 types of gasket/seals
the rubber type U can easily over tighten n cause a leak
if U use the thik cardboard type U can't over tighten to cause a leak
think n the rubber one is narrow and easyto mis align where by the cardboard is wider
gudday m8
Last edit: 3 years 1 month ago by Swishy.
3 years 1 month ago #220249
Replied by asw120 on topic Spin on oil filters for International 6-281
2 possibilities here. The one on my Inter leaked like a sieve. The housing was bent.It wasn't the only bent one I had!
I found a straight one and all OK, although it is still tricky.
I had D1110 previously with a Z74 (I think?). It was factory.
They are about, but not easy to find.
3 years 1 month ago #220251
by Merrick
Replied by Merrick on topic Spin on oil filters for International 6-281
I'm thinking mine may be a little askew, although it actually just started one random day, I hadn't touched the canister for months.
Alas Swishy, the Ryco filters come with two rubber rings, no cardboard at all.
I'd be interested in finding a late D line one and taking the filter unit off it, if it's a straight swap.
- Thank you received: 600
3 years 1 month ago #220257
Replied by 180wannabe on topic Spin on oil filters for International 6-281
After Easter, i'd suggest having a look on ebay to see if "Waggatractor" list a spin on filter head conversion. I just tried to have a look now, but see he is away until after the 5th, and has pulled his listings while away.
Great bloke to deal with, i have bought from him quite a few times.
Brett.
Brett.
- Thank you received: 19
3 years 1 month ago - 3 years 1 month ago #220260
by projectinter
Replied by projectinter on topic Spin on oil filters for International 6-281
Last edit: 3 years 1 month ago by Sarge.
The following user(s) said Thank You: Merrick
- Thank you received: 4775
3 years 1 month ago #220262
Replied by Mrsmackpaul on topic Spin on oil filters for International 6-281
If it was a Dodge I would suggest the oil pressure regulator bypass doohikie is stuck shut and this causes full pressure to pump thru the filter and the buggers leak like theres no o ring at all
Quite often you can just turn them off and start them again (might have to do this a few times) and the regulator opens up all is good till next time
Only seems to happen if they have been sitting for a while
Is this motor a full flow filter or a bypass filter ?
3 years 1 month ago #220265
They're full flow.
3 years 1 month ago #220274
Replied by JOHN.K. on topic Spin on oil filters for International 6-281
The filter mount on an IH281 isnt too solid,and its easy to distort the ally head so the O ring doesnt seal all round......the spin on mounts IIRC used be less than $10 from IH-now IVECO-and id try them first ....they still have a surprising range of old IH petrol spares.........unfortunately my D Line parts book is pre spin on ,so no part no.
3 years 1 month ago #220275
Replied by Sarge on topic Spin on oil filters for International 6-281
I happen to have this copy of a ryco filter sheet for inter, not great copy but maybe of some use
Not great quality and the original is 1000k away atm.
Time to create page: 0.621 seconds
