- Thank you received: 2501
Freuhauf Trailer..... How old???
11 years 10 months ago #87537
Freuhauf Trailer..... How old??? was created by hayseed
I've recently Purchased this Trailer, & got It home on Tuesday.
As you can see It's fairly straight & unmolested.
I've had a few Fruehauf trailers over the years, But I've never seen these cast hangers & rocker boxes.
Can anyone tell Me ,when they changed over to this Pressed type of hanger/rockerbox????
[IMG]
Photo Borrowed from Scummy's post in the spread trailer thread.. (thanks scummy)
[IMG]
11 years 10 months ago #87538
Hay
Seed
Gr8 Pix
Keep m Cummin
th@ trailer looks good
stihl got a positive camber in the deck
guess n age L8 50's or 60'z
Should/would/could buff up Ok
orll it needs iz sum elbow grease
[ch9787]
Replied by Swishy on topic Re: Freuhauf Trailer..... How old???
Hay
Seed
Gr8 Pix
Keep m Cummin
[ch9787]
8 years 10 months ago #87540
Replied by Swishy on topic Re: 36ft Fruehauf Slider
BC model
8 years 10 months ago #87541
by Ronny G
Replied by Ronny G on topic Re: 36ft Fruehauf Slider
Looking at your photos Hayseed,I would say that your deck is around 1973 as it looks the same as my 34 footer.Same rear end,tail lights, coming rail etc.But the Bogie assembly looks much older.Mine has the compliance plate on the left side with serial no and date.Can you find anywhere on a cast bit of the Bogie that might have Fruehauf imbossed in the cast.
Cheers Ron
Cheers Ron
8 years 10 months ago #87542
Guys
FWIW
We bought a 2nd hand Fruehauf extendable semi (37'-57')
in 1972 n it twas a few years old then
and looks more modern than the above pix
it had a more refined slide n pin set up and with the pineapple shaped plastic hub/bearing caps
so guessn ours twould B mid to L8 60's
FWIW
8 years 10 months ago - 8 years 10 months ago #87539
Replied by hayseed on topic Re: Freuhauf Trailer..... How old???
To save hijacking Debos' thread I've split & spliced off topic replies to here..
Last edit: 8 years 10 months ago by hayseed.
8 years 10 months ago #87543
Ronny, I know the plate you're talking about But It's missing from this trailer.
Both beams have been repaired just behind the Skid plate.
if you look at the 4th pic down,On the Rocker hanger you can see some embossed writing. It says Fruehauf & a part No.
I'm inclined to agree with Swishy's call of Late 50's early 60's.
The Axles are the early I beam Fruehauf.& the top is 35'X8'
I was just Hoping someone could tell Me when they stopped using the cast Suspension & released the Pressed/fabricated Suspension.
I might have to ask the yanks!
8 years 10 months ago #87544
by Ronny G
Replied by Ronny G on topic Re: Freuhauf Trailer..... How old???
Hayseed what type of hubs are on your trailer? Have you any photos of the hubs? I tend to think the Bogie assembly is a lot older than the deck.I posted some photos of our older trailer on Debos thread showing an obviously early stile of hub and the combing rail has straight sides but this one has a different air bag suspension to Debos but I don't know the age of this one.
Ron
Ron
8 years 9 months ago #87545
by rex
Replied by rex on topic Re: Freuhauf Trailer..... How old???
Hayseed, In as much as it worries me to agree with Swishy, you never know what he will come up with if he thinks he is right about something. But given my first encounter with Fruehauf was in 1965 with a 4 or 5 year old Trailer, I was 19 at the time, that would give the Trailer late 50s or early 60s. The Trailer had the square axles with the threaded hub cap. I would therefore put it at somewhere in the 50s, I did come by a Dolly years ago with the I beam axle, not sure of the whereabouts now but might still have some bits.
What you have there is a piece of History and deserves to be restored, Fruehauf built very good Trailers and in many ways were ahead of the competition with their engineering and design.
Rex
Rex
8 years 9 months ago #87546
by defective
Replied by defective on topic Re: Freuhauf Trailer..... How old???
...you can tell she's pretty old also by the individual rear lights in their recesses...combination tail/stop/blinkers were a new thing early 1960's...??
Time to create page: 0.559 seconds
