- Thank you received: 4807
Some questions for the rivet counters
- Mrsmackpaul
1 year 6 months ago #240863
Some questions for the rivet counters was created by Mrsmackpaul
Seems like some of you lot know quite a lot about Kenworths, I know not a lot, even less than I know about Macks which really is bugger all
Photo for reference, when did the headlights go larger round lights with out the cluster ?
Did this happen all at once or was it a option for a while ?
1 year 6 months ago #240864
by werkhorse
Replied by werkhorse on topic Some questions for the rivet counters
Around 1978 the change was made .... Not exactly sure if there was a certain chassis number that the change occurred on or if it was an option for a short while.
It basically coincided with the release of the 2200 series cab over cab on the K100 series.
The following user(s) said Thank You: 180wannabe, oliver1950
- Mrsmackpaul
1 year 6 months ago #240866
Can you shed some more light on what 2200 series change was ?
I thought the Kenworth cabbed stayed the same for real long time, like well into the 90s
Replied by Mrsmackpaul on topic Some questions for the rivet counters
1 year 6 months ago #240868
by werkhorse
2.2 m sleeper cab ... Was the main difference visual ... Lots of smaller things changed that were not so visible
- Mrsmackpaul
1 year 6 months ago #240869
Was this when the one piece fiberglass roof was fitted to the K 100 ?
I might even have that wrong :oops:
Did thr Kenworth cabs come like Mack cabs to Australia
Let me explain that dumb ass question
Mack cabs came finished? As a LHD cab (talking R and F model cabs) and all the holes were drilled for LHD in the fire wall etc
Mack had template or templates that marked out the cabs for RHD
When the cabs were built up RHD all the excess holes were covered up and you couldn't tell until you pulled the truck apart
Were Kenworth cabs like this or were they all built RHD from new ?
- Mrsmackpaul
1 year 6 months ago #240880
Apparently the top photo the truck is on torsion bars (face book is full of experts), can this be told by the photo or is it because people know the truck
Can torsion bar parts be sourced these days, I ask because Macks camel back are still about everywhere and there is plenty of aftermarket parts for them for just about every part you can think of
From what I understand these torsion bar setups were all removed in later life for what ever reason, ride ? parts ? bad wear characteristics ? Maybe a bit of everything
1 year 6 months ago #240886
Paul, they need a lots of regular Greasing. & to do It properly You needed to jack the Chassis up so there was No weight on all the Bushes.. Most Blokes were in Too big a Hurry to do that which led them wearing Out quickly..
From memory, A Brand new reyco 4 spring suspension Kit was roughly the same price as all the Bushes to rebuild one, & if the Hangers were Flogged out (Due to lack of Grease) a HEAP cheaper...with very little ongoing Maintainence.
Replied by hayseed on topic Some questions for the rivet counters
- Thank you received: 839
1 year 6 months ago - 1 year 6 months ago #240888
by BillyP
How ever ......... if you said T/Bars you probably would be spot on ........
Yep....... lack of grease was the greatest enemy...........
Some owners who did the right thing, never replaced a thing in the life of the truck ............
So best idea is to carry a grease gun in your back pocket...........
............(looks like one of the local coal trucks of the era )................
................Billy.....................
I used to be a truck driver,
on a good day i can remember
Replied by BillyP on topic Some questions for the rivet counters
From that pic there is no way of knowing if it was fitted with T/Bars. Unless you knew the truck or the specs .............Apparently the top photo the truck is on torsion bars (face book is full of experts), can this be told by the photo or is it because people know the truck
Last edit: 1 year 6 months ago by BillyP.
1 year 6 months ago #240949
by BillyP
When the KWs were started to be built in OZ the cabs were built here as required.............(may be a few were imported initally ...maybe.......).
Unlike other cabs that involved a lot of welding...........the KW cab was bolted (or riveted) together and could be completely tore down and rebuilt..........
At Lansvale and St Peters we had a jig to build the cabs up from nothing to the completed item........... then it would just pop on
to the chassis with no trouble at all...................
Or, we could use that jig to do a repair job as required..............
....................Billy......................
1 year 6 months ago #240952
by eerfree
Bob,
I do not know how I got over the hill without ever getting to the top.
Replied by eerfree on topic Some questions for the rivet counters
Bob,
Time to create page: 0.548 seconds
