- Thank you received: 1130
Help needed from the brains trust
- oliver1950
5 months 3 weeks ago #249166
by oliver1950
You can't have too many toys!
Help needed from the brains trust was created by oliver1950
I have a 1992 Daihatsu Delta V10D with a Toyota 3B motor in need of a head. I can't find a head but I found a Toyota B motor and gearbox out of a Daihatsu for $600. My question is will the Toyota B and gearbox fit straight in ; engine mounts and wiring compatible? it is about 600 km away so can't just go and look at it. I know I will be dropping 10hp in power but it is a farm tipper and will rarely be in any gear above 3rd due to the hilly nature of the country around here. Or does anyone know where I can find a head?
5 months 3 weeks ago #249167
Replied by Lang on topic Help needed from the brains trust
5 months 3 weeks ago - 5 months 3 weeks ago #249168
Replied by jon_d on topic Help needed from the brains trust
The forum won't let me post a link to ebay.
Search on ebay for item 266295350554
It's a link to a new 3B bare head.
Last edit: 5 months 3 weeks ago by jon_d.
- oliver1950
5 months 3 weeks ago - 5 months 3 weeks ago #249169
by oliver1950
Thanks, that is the later model head different to mine
Replied by oliver1950 on topic Help needed from the brains trust
Last edit: 5 months 3 weeks ago by Gryphon.
5 months 3 weeks ago - 5 months 3 weeks ago #249176
by roKWiz
Heritage Stonemason
Replied by roKWiz on topic Help needed from the brains trust
Is it a indirect injection head. 4 glow plugs.
This 3B head looks similar (in Melbourne)
www.facebook.com/marketplace/item/604685...rral_story_type=post
Heritage Stonemason
Last edit: 5 months 3 weeks ago by roKWiz.
- oliver1950
5 months 3 weeks ago #249180
by oliver1950
Thank you but not the same . That is the later type with the tappet cover bolted around the outside, mine has 4 bolts through the centre of the tappet cover.Is it a indirect injection head. 4 glow plugs.
5 months 3 weeks ago - 5 months 3 weeks ago #249182
by roKWiz
Heritage Stonemason
Ok, I thought the later 3B mk 2 had the 4 internal retainer studs for the rocker cover.
Just curious......Is it a 12v or a 24v engine, ??
is it indirect injection or direct injection. ??
Does it use the rotary pump or inline Kikki pump.??
Heritage Stonemason
- oliver1950
5 months 3 weeks ago #249184
by oliver1950
indirect injection
Kikki injector pump
apparently not the original engine
24 voltOk, I thought the later 3B mk 2 had the 4 internal retainer studs for the rocker cover.
indirect injection
Kikki injector pump
The following user(s) said Thank You: roKWiz
5 months 3 weeks ago #249185
by roKWiz
Heritage Stonemason
Interesting how they changed over the years. I had a 83' 3B V48 Delta. 24V was a pain when it came to headlights constantly blowing globes.
A little googling tells me a 1 before 3, 4, 5B means direct injection and the later blocks didn't have liners. never knew that, so I've learnt something new today.
Hope you can find the head you need.
Heritage Stonemason
The following user(s) said Thank You: PaulFH, oliver1950
- oliver1950
5 months 2 weeks ago #249341
by oliver1950
I took the plunge and bought the B motor and gearbox, picking it up Tuesday. Thank you all for your interest and help.
Time to create page: 0.563 seconds
