- Thank you received: 126
Brains trust , I dunno what it is
7 years 4 months ago #177841
by ianoz
Brains trust , I dunno what it is was created by ianoz
7 years 4 months ago #177844
by oldgmc
Replied by oldgmc on topic Brains trust , I dunno what it is
I think I know this truck, near sawmill at Bilpin on Bell of Line Road, the bonnet has been extended it could be a Kenny or Ward Lafrance, the tin ware near the jerrycan is the same to and you can see the spring hangers on the chassis and it appears to be extended not original chain drive check out welds on chassis just behind original spring hangers shes a real bitsa
7 years 4 months ago - 7 years 4 months ago #177845
Replied by Lang on topic Brains trust , I dunno what it is
Looking at the guards, I think these appear home made - then again???
The FWD theory does not stack up when the two vehicles are compared.
The Ward LaFrance/Kenworth looks more like it. I don't think the bonnet is extended - just a bit of rough tin. The radiator cowl or tin-work is missing just leaving the support frame.
Look at the mudguard design.
The angles seem a bit wrong on John Belfield's Kenworth but pretty close.
The other prime suspect is a Diamond T but although the radiator/front spring relationship is right the cab design and swept up chassis rails don't do it.
Last edit: 7 years 4 months ago by Lang.
- Thank you received: 4807
7 years 4 months ago - 7 years 4 months ago #177847
Replied by Mrsmackpaul on topic Brains trust , I dunno what it is
I have noticed it has extra unusual spring hanger type doo days in front of the chain drive diff
I wonder could this have been a half track machine with them extra spring hangers ?????? but I have no idea at all
But I reckon Langs middle photo in the last post is about the closest it has the little checker plate step welded onto the rear of the mud guards
Last edit: 7 years 4 months ago by Mrsmackpaul.
7 years 4 months ago - 7 years 4 months ago #177849
I don't think it is a half track with a different cab. They were relatively lightly constructed compared with the Ward LaFrance/Kenworth machines.
The half track suspension was a volute spring (in the square box) not a conventional spring requiring hangers. For interest a volute spring is like the spring on garden hand pruners and allows a lot of spring action in a very short distance.
7 years 4 months ago #177850
Replied by hayseed on topic Brains trust , I dunno what it is
I've got NFI what it Is/was..
But I think It has had a Pusher axle under it at some stage, going by the set of spring hangers in front of the drive axle..
http://www.hcvc.com.au/forum/attachment/3337
7 years 4 months ago #177852
Replied by Swishy on topic Brains trust , I dunno what it is
Guess n the xtra spring hangr doodadds could've been a home grown pusher axle
7 years 4 months ago - 7 years 4 months ago #177853
Drive is definitely Mack. The extra spring hangers seem rough as guts and not a factory item. The ring-in pusher seems likely.
Maybe it is not as complicated as we think. Could it just be a Mack chassis and rear running gear grafted straight on to a WLF/KW chassis at the point where chassis rail size changes at the front "pusher spring hanger" with few other changes?
7 years 4 months ago #177860
Replied by Dave_64 on topic Brains trust , I dunno what it is
Like Hayseed, I too have NFI !But, you have to admit it has a certain "rustic" charm.
What caught my eye was just how close the rear spring hanger mount was to the end of the chassis, but if it's a "Bitsa", maybe somebody took to the chassis rails with the gas axe??
Dave
Dave
Time to create page: 0.604 seconds
