- Thank you received: 91
Sound Proofing and Vibration Dampening
9 years 4 days ago - 9 years 4 days ago #159150
by Bobsboy
Mucking about on the edge
Sound Proofing and Vibration Dampening was created by Bobsboy
Hi,
My wagon has as much vibration and drumming in it as a Bass Strait Ferry.
Vibration I imagine, is mostly finding the offending structure and bracing and bashing it into a new frequency. Any other thoughts?
Drumming and humming I guess would be solved with a 'product' i.e. matting or stick-on type stuff.
Any of you have experience with some thing that worked for you?
What's it called and where did you get it (at the best price)?
Thanks in advance,
-b
Thanks in advance,
-b
Last edit: 9 years 4 days ago by Bobsboy.
9 years 4 days ago #159151
Replied by Swishy on topic Re: Sound Proofing and Vibration Dampening
Bobz Buoy
M80
easy fix
http://t1.gstatic.com/images?q=tbn:ANd9GcTBFcvLkG-E0fRL1s4hRRJZS9crGZwCFGH3L6Oi7n8ZBxlqlhpo
https://encrypted-tbn3.gstatic.com/images?q=tbn:ANd9GcTmIdCLhwym2SqtPzLg4p5j54w6JSEC8DjeOOPUllp1uKcWpSpb
n turn it up Hi
M80
easy fix
n turn it up Hi
- Thank you received: 4882
9 years 4 days ago - 9 years 4 days ago #159152
Replied by Mrsmackpaul on topic Re: Sound Proofing and Vibration Dampening
Vibration is usually something wrong out of balance ect tail shaft unis bent tail shaft crook wheel bearing once you start looking you might wish you hadnt LOL
hang on whats this wagon anyway have I missed something ???
Last edit: 9 years 4 days ago by Mrsmackpaul.
9 years 3 days ago #159153
by cymro
Replied by cymro on topic Re: Sound Proofing and Vibration Dampening
Look up Pyrotek sorberfoam v on google.Ive used something like this on the firewall inside the cab on the Thorny.They covered the roof and walls of the pushback tugs at work.
9 years 3 days ago #159154
by RossH
Replied by RossH on topic Re: Sound Proofing and Vibration Dampening
I bought soundproofing from Rare Spares and fitted it to the firewall and back of the cab. Economical and really easy to work with.
9 years 3 days ago #159155
Replied by on topic Re: Sound Proofing and Vibration Dampening
Sound Proofing. I was having some sheet metal work done for my patio and I saw some aluminium backed fairly solid but pliable foam that is sticky once you remove the protective paper. It's about 12mm thick.
I asked if they had any off cuts and they gave me enough to do my Truck.
Don't know what it's called but any Aircon Duct manufacture/sheet metal worker would have some.
Daz
Daz
9 years 3 days ago - 9 years 3 days ago #159156
by Bobsboy
Replied by Bobsboy on topic Re: Sound Proofing and Vibration Dampening
Hi,
Thanks guys,
you've given me food for thought and a next direction to explore.
Mr Swishy,
I tried the bottle trick but after breaking two bottles, I drank the remainder and only managed to blur my vision.
Not the solution I was looking for.
The previous owner put in a good radio (I think it even has a CD player) but it's only a partial and temporary work around.
Msmackpaul, you may be on to something there, while it was on the second yard (for consignment sale) it was mentioned in passing that the 'silent shafts' (engine balancers) may not have been correctly reinstalled when the timing belts were done, before I purchased it.
That licenced mechanic/ dealer, whom I still use and trust, sort of poo poohed that idea.
But, before I spend money and effort with 'product' & more metal bashing (after the cuts heal),
I will explore that angle in greater detail with a discrete second opinion.
Ta again,
-b
Thanks guys,
Mr Swishy,
Ta again,
-b
Last edit: 9 years 3 days ago by Bobsboy.
9 years 3 days ago #159157
Replied by mammoth on topic Re: Sound Proofing and Vibration Dampening
UES International is a one stop shop for fitting out truck and bus bodies and have different versions of what you might be looking for. They have an on line catalogue and an outlet in Adelaide.
9 years 2 days ago #159158
by podge66
Replied by podge66 on topic Re: Sound Proofing and Vibration Dampening
Try dynomat siler paper with bitumen on the back , l use it in the truck restorations and the hot rod boys use it to cuts noise and heat podge 66
9 years 1 day ago #159159
by tim
Replied by tim on topic Re: Sound Proofing and Vibration Dampening
Bobsboy, I,d check out the vibration, out of balance side of it first, because that could be the source of your noise issue as well. If something is out of balance it will create noise as well as vibration. Cheers Tim.
Time to create page: 0.626 seconds
