- Thank you received: 4
Brake wheel cylinder
6 years 1 month ago #192960
by Hemi74
Brake wheel cylinder was created by Hemi74
Got my rear wheel cylinder reco on the 300 series d5n and little did I know it had a fracture in the bleed nipple in casting , I have a 114 at4 out the farm , anyone know if there the same wheel cylinder ? The one from the d5n has Bendix 302857 stamped on it
Cheers brad
Cheers brad
6 years 1 month ago #192961
by Hemi74
Replied by Hemi74 on topic Brake wheel cylinder
They are both full hydraulic set up , no air
6 years 1 month ago #192962
Replied by JOHN.K. on topic Brake wheel cylinder
Thr brakes are likely Duo=Servo....and the same style of brakes were fitted to most small trucks.,not jappas obviously.....just look for the same bore wheel cylinder.....Your system will be vac boosted with a PBR VH44 booster.
6 years 1 month ago #192964
by Hemi74
I ended up drilling it out to and putting a 3/8 unf helicoil in and used some red thread locker on helicoil
Trying to save it , it's anadized with stainless sleeve and alloy pistons
6 years 1 month ago #192971
Replied by asw120 on topic Brake wheel cylinder
3 series will have much bigger back brakes than 1 series. Sounds like you've rescued it, anyway.
6 years 1 month ago #192977
by Old Fargo
Replied by Old Fargo on topic Brake wheel cylinder
hello thank you all for your advice, my dodge at4 was finished, road registered, driven and now sold. my health will prevent another project so thanks again cheers (want my user name ask admin if you are allowed its yours)
6 years 1 month ago #192981
If you are driving on the road with one wheel cylinder with a cracked bleeder boss,held with a helicoil....you are tempting fate........remember your dodge is only single line brakes.
Time to create page: 0.486 seconds
