- Thank you received: 4
Wheel brace d5n
5 years 11 months ago #193581
by trucksyd
Wheel brace d5n was created by trucksyd
G'day, I've got a d5n 300, with 25mm front wheel nuts & 28 mm rears, I havnt got a wheel brace for it so I tried using the 28mm sockets with a sidchrone bar .it bent it & still didn't loosen the nut.what are youse blokes using to get your wheels off ?& where do u buy them from ...thanks...
5 years 11 months ago #193584
Replied by JOHN.K. on topic Wheel brace d5n
Not left hand thread ,are they?
5 years 11 months ago #193585
by trucksyd
Replied by trucksyd on topic Wheel brace d5n
No standard thread ,I think they're imperial ,but the sockets fit .
5 years 11 months ago #193586
Replied by Swishy on topic Wheel brace d5n
TrukSyd
gudday m8
make sure they B metric or imperial
wot we do is go buy a 6 sided 3/4 or 1" drive socket
normally @ a trash n treasure or garage sale
in your case buy the 2 sockets n weld one each end of a 500mm HD bar
then weld nuther HD cross bar slightly off center towards the front wheel size socket
WamBamThankUMama = dun deal
ยง
gudday m8
ยง
5 years 11 months ago #193587
by trucksyd
that makes sense thanks swishy :oops:
5 years 11 months ago - 5 years 11 months ago #193591
Replied by Dave_64 on topic Wheel brace d5n
Made mine out of a 32mm X 3/4" drive socket welded to about 15" of heavy wall steam pipe, drilled two 5/8" holes opposite each other, slip binder bar in and stand on the little buggers!
Works for me every time, even when I forgot to remember that passenger side studs were L/H threads!
Also doubles as a "knockometer" (hammer).
Dave.
P.S. IF your like me and find that your Whitworth spanners/sockets are getting a bit hard to find these days, for some strange reason metric spanners/sockets seem to come closer than AF (SAE).
Dave.
Last edit: 5 years 11 months ago by Dave_64.
5 years 11 months ago #193596
Syd, I use one of these..
My 8 yr Old son can undo ten Stud Alcoa Wheel nuts (450 ft/lb) for Me.
Replied by hayseed on topic Wheel brace d5n
trucksyd wrote: I tried using the 28mm sockets with a sidchrone bar .it bent it & still didn't loosen the nut...
Time to create page: 0.457 seconds
