- Thank you received: 66
Strange Clutch ??
- Rattail 1927
4 years 6 months ago - 4 years 6 months ago #203829
by Rattail 1927
Strange Clutch ?? was created by Rattail 1927
So clutch in my T-Line needs adjusting so I got a mate to look at it for me.
Only to find out it’s nothing like him nor I have seen before, it’s got a strange cover with 2 bolts holding the adjustment in place.
Only to reveal what I’d call a ring gear inside??
Can anyone help me ? Found nothing on google? The picture is the retainer ?
Last edit: 4 years 6 months ago by IHScout.
4 years 6 months ago #203831
by werkhorse
Replied by werkhorse on topic Strange Clutch ??
There's only two types of manual adjusters on these old clutches.... Originally you unbolted the tag and used a screwdriver to turn the clutch plate.. They had aquare lugs on the back of the plate.... Then they went to a push in bolt looking thing... Kinda like a brake adjuster that you put a spanner on and pushed the whole bolt thingy in and turned to adjust.... Been a bloody long time since I've adjusted a clutch but it looks like half of the later one.... I'd say it's broken off the bolt part of the adjuster...
4 years 6 months ago #203841
by Zuffen
Replied by Zuffen on topic Strange Clutch ??
That weld looks fairly average. About as good as mine!
Perhaps that's an indication its had prior failed attempts to resurrect it.
- Thank you received: 839
4 years 6 months ago - 4 years 6 months ago #203842
by BillyP
I used to be a truck driver,
on a good day i can remember
Replied by BillyP on topic Strange Clutch ??
.Many moons ago Spicer brought out a self adjusting version of the 15 1/2 " clutch.
That worm turned the inner adjusting ring , ( the ring gear as you called it ), by a ratchet sort of gismo. (that is now ratshit ).
The ratchet gismo was operated by the throw of the clutch.
It was a dismal failure , simply because clutch dust gummed up the works and the bits eventually mostly broke up.
Unfortunately I cannot remember what it all looked like , but my guess is that is what it is .
To adjust the clutch now , you remove that worm bisso (as you have done), then with some one depressing the clutch pedal,
the ring can be turned with a lever of sorts ,( provided it has not seized up ) to get your correct clearance.
Then get the ring in the right spot so that you can replace that worm gadget (. Or rotate the worm if you can, )
That's it. ………….. That is my guess .
…………………….Billy...………………...
Last edit: 4 years 6 months ago by BillyP.
- Rattail 1927
4 years 6 months ago - 4 years 6 months ago #203847
by Rattail 1927
Replied by Rattail 1927 on topic Strange Clutch ??
Last edit: 4 years 6 months ago by Rattail 1927. Reason: Add pictures
- Rattail 1927
4 years 6 months ago - 4 years 6 months ago #203876
by Rattail 1927
Last edit: 4 years 6 months ago by Sarge.
4 years 6 months ago #203879
Replied by JOHN.K. on topic Strange Clutch ??
While you re looking at stuff,check the springs for buckling......one thing about the angle spring clutches,bits are very cheap...compared to something like a Fichtel and Sachs,where everthing is weight in gold.........you can adjust the clutch by yourself,just block up the pedal with a block of wood.,the ring must turn free..
4 years 3 months ago #205871
by jeffo
Replied by jeffo on topic Strange Clutch ??
Easiest way to rotate an engine is to jack up a wheel, put her in top gear and bar her slowly over on the universals.
Good for valve clearances etc.
Two speed diff was brilliant as you could get them in neutral by a quick on/off on the IGN key. Made greasing the old Commer tailshafts a piece of cake.
Time to create page: 0.473 seconds
