- Thank you received: 49
Kingpin oil?
10 years 1 month ago #139577
by ashmenz0
Kingpin oil? was created by ashmenz0
Hi Folks
I am told that our old bus has a Leyland front axle and both kingpins have a "bit" of slop in them.
There appears to be an oil reservoir on the top of the kingpin, with a brass bung in the top . Is this what it is, and if so can anyone recommend what oil should go in them?
Thanks
Ash
Thanks
Ash
10 years 1 month ago #139578
by atkipete
Replied by atkipete on topic Re: Kingpin oil?
I have only ever seen grease nipples on kingpins. Can you put a photo up ?
10 years 1 month ago #139579
Replied by bigcam on topic Re: Kingpin oil?
They are greasers.
You take the cap off, fill the cap up with grease, and then as you screw it down it forces the grease in.
10 years 1 month ago #139580
by busntruck
Replied by busntruck on topic Re: Kingpin oil?
It's not fitted with "button" grease nipples is it?
Lots of Leyland buses were fitted with these.
From memory some Albion's & Scammells had king pins that used an oil and not grease.
- Thank you received: 19
10 years 1 month ago #139581
by 14B-Beaver
Replied by 14B-Beaver on topic Re: Kingpin oil?
Hi,
We got a new Beaver in 1964 and it ran heavy gear oil in the King Pins. The oil we used was Mobil Lube GX140. The grease nipples were of the button head type.
10 years 1 month ago #139582
by ashmenz0
Replied by ashmenz0 on topic Re: Kingpin oil?
Hi Atkipete, I will try and put up a photo when I have a chance.
At the top of the kingpin there is a "reservoir" that sort of looks like the cover you put on our towball. This has a brass plug screwed into the top which is quite big. (It takes a 20mm spanner)
Hi Bigcam, do you mean take the whole unit off or just the cap in the top of it?
Hi Busntruck, I am not sure what a "button" grease nipple is. It has a standard grease nipple on the very bottom of the kingpin though.
Hi 14B-Beaver, it may have had oil inside as it is pretty clean down in the hole.
Will try and work out the whole picture thing and get one up here.
Thanks very much to everyone, Your help is very much appreciated.
Ash
Ash
10 years 1 month ago - 10 years 1 month ago #139583
by ashmenz0
Try this pic. Looking down with the bung removed from the top of the cap.
http://rs215.pbsrc.com/albums/cc311/ashleymenzies/005a.jpg~c200
Ash
Ash
Last edit: 10 years 1 month ago by ashmenz0.
10 years 1 month ago #139584
by ashmenz0
One more pic showing it from side on.
http://rs215.pbsrc.com/albums/cc311/ashleymenzies/011a.jpg~c200
Ash
Ash
10 years 1 month ago #139585
by HEOFTHEHUM
Replied by HEOFTHEHUM on topic Re: Kingpin oil?
Its looks like a pot for "FLOWABLE GREASE" as used in "Albion" brand gearboxes, Leyland on board greasing systems etc. Shell Rentinax Grease CS00, semi-fluid for centralised lubrication systems, i have a 2.5 kg tin, probably comes in all sizes.
Time to create page: 0.535 seconds
