Dented Fuel Tank
8 years 9 months ago #161114
by Ronny G
Dented Fuel Tank was created by Ronny G
We have just bought a CHR Mack for the farm.She should tidy up OK but has a couple of dents in the left side aluminium fuel tank.Is it possible to get them straightend, or buy a new tank
8 years 9 months ago #161115
Replied by Swishy on topic Re: Dented Fuel Tank
Ronny G
Wot eye twould suggest ifn U dun wanna newer tank
Make sure u're life insurance iz fully paid up
Depend n on dents
n how sharp the crease iz
blank off all hose connections
place air fitting
inflate with a gauge Guessn 50psi
wak around the dent wiff a rubber mallet
1 of 3 things could happen
<1> the dent is fixd n removed
<2> the dent jist looks the same
<3> the ambulance iz on its way
Probly bettr to bung up sum pix
BestoLuckO
Depend n on dents
place air fitting
BestoLuckO
8 years 9 months ago #161116
by Mairjimmy
Replied by Mairjimmy on topic Re: Dented Fuel Tank
If you go to 50psi I know you will be able to fit more fuel in it after, it may look like a wine barrel and the ends rounded as well
Colin
Colin
8 years 9 months ago #161117
by Zuffen
Replied by Zuffen on topic Re: Dented Fuel Tank
Rather than filling with air, use water and then pressurise it.
Water being incompressible won't explode like air.
When gas cylinders are tested they use water for that reason.
Basically I would do what Swishy said but try at a lower pressure with water and work your way up if needed.
8 years 9 months ago #161118
by dieseldog
Replied by dieseldog on topic Re: Dented Fuel Tank
Depending on the thickness of the tank material, a plumbers plunger will work wonders...
8 years 9 months ago #161119
by dno
Limited Access Excavations.
Replied by dno on topic Re: Dented Fuel Tank
I have heard of guy's with round tanks having an end removed and re-rolling but I've also heard a common fix was to remove it and refit it end for end, putting the dent on the inside. Probably not possible on all round tanks without some welding.
8 years 9 months ago #161120
by andy950
Replied by andy950 on topic Re: Dented Fuel Tank
Cant turn around mack tank or Kenworth tanks because of were the pick ups are
8 years 9 months ago #161121
by defective
...g'day dno .. we did that end for end, but also side for side (for the fittings to work more easily on dual tanks) back when the painted steel tanks were all about...especially the Whites
Replied by defective on topic Re: Dented Fuel Tank
8 years 9 months ago #161122
Replied by jon_d on topic Re: Dented Fuel Tank
Wouldn't it be best to call the ambulance first?
Then fill it with air.
8 years 9 months ago #161123
by dno
I've seen plenty of tanks used as wheel chocks by bad operators over the years, the plastic cab tanks used to cop a flog'n too.
Time to create page: 0.487 seconds
