- Thank you received: 4809
Tri-axle trailers with singles on front axle
- Mrsmackpaul
2 years 7 months ago - 2 years 7 months ago #226382
Tri-axle trailers with singles on front axle was created by Mrsmackpaul
This must of been one of the very early tri axle trailers with only single tyres on the front axle, not many like this until duels went all the way around
Last edit: 2 years 7 months ago by Mrsmackpaul.
The following user(s) said Thank You: overlander, PaulFH
2 years 7 months ago #226432
by PaulFH
Replied by PaulFH on topic Tri-axle trailers with singles on front axle
Used to see tandem axle semi tippers with spares mounted upright
in front of the axle group. looked twice at first, but that's how they
were done. Just an alternative idea maybe. Paul.
- Mrsmackpaul
2 years 7 months ago #226448
Replied by Mrsmackpaul on topic Tri-axle trailers with singles on front axle
I am 1000% sure that the very first tri axle trailers only had single wheels on the lead axle as shown in the last two tipper photos
They must of only been made this way for a very short period of time before becoming duals all around
75 - 76 maybe, with time and research I could probably narrow this right down even closer
Some even had a small spread between the lead axle and the close coupled bogies
There were many variations at the start until it settled down to 3 common spreads and configurations
2 years 7 months ago #226463
by PaulFH
Think you're correct Paul. Closer look reveals all 3 rows under the guard.
Did not realize they were built this way. Saw the odd single axle trailer
fitted with a single tyred axle in front of the original duals. probably to
overcome running heavy on the trailer axle back in the day.
The semi tippers with spares mounted upright in front of the axle group
always looked a bit strange to me, but suppose that was practical.
paul.
paul.
- Mrsmackpaul
2 years 7 months ago #226685
These just appeared on Facelessbook, tri axle trailers with single tyred lead axle like I mentioned the other day
So very early 70's foe this style tri
Photo credit to Martin McCourt and Atlantic Ron for their pictures from Facelessbook
From Martin McCourt "Cartting rock into botany bay for container terminal around 1970/71trucks were Mack power pups with twin sticks."
2 years 7 months ago #226693
by PaulFH
Thanks Mrsmackpaul, quite a transitional axle group which I had not noticed.
Saw the arrangement in a FB photo Monday, on a flat top trailer too. Paul.
2 years 7 months ago #226694
by wee-allis
Replied by wee-allis on topic Tri-axle trailers with singles on front axle
The first of this system not only had just a single wheel, but had no brakes fitted to that axle either. I remember LIndsays, in the early to mid 70s had a few of them, but soon fitted them up with duals and brakes. One major problem was, get a flat on a single wheel and before you could do anything about it, you have lost a tyre. I think the no brakes issue was settled by the Government Regs at the time.
- Mrsmackpaul
2 years 7 months ago #226697
I only recall seeing this style of axle set up on tippers, I guess that shows just how easily we all forget things
I feel these would of been converted to duals all around very quickly as Im guessing that the lead axle is the same width as the other two axles
On a completely unrelated note, in my collection of McGrath axles I have two from a 23 foot dog trailer that was a 1970 model, anyway the way I ended up with the axles was that they had been replaced in recent years, at a guess 2015 ish or there abouts
Because the dolltend of the axles had no brakes when new
The owner was selling the trailer and in the add it had new axles fitted and I made enquiries about the old axles and their were abouts and thats w hen I learnt this
The front axle has no mountings for brake shoes or backing plates and the spiders have no holes for drums
This axle had duals fitted, anyway as I said completely unrelated almost
Well I was gunna add a photo but the forum says that they are forbidden, tried resizing, still forbidden
So if you all close your eyes real tight and imagine a McGrath axle laying on the dirt in a paddock that will have to do :woohoo: :woohoo:
Maybe the link above might work, other than that, just stick with plan 'A' and imagine the axle
- Mrsmackpaul
2 years 7 months ago #226698
Looks like the link worked
2 years 7 months ago #226701
by xspanrman
Replied by xspanrman on topic Tri-axle trailers with singles on front axle
Heggie's Transport had 6 tipping coal trailers (3 Alcan and 3 Highgate) in the early 70's with a lift up single tyre axle. To lift the axle 2 air bags pushed a frame forward which tightened 2 wire ropes that ran over pulleys and was secured to the axle. 2 different airbags were used to push the axle down. A later coal trailer had a leaf spring to lift the axle and air bags to push the axle down. I think this type of lift up axle was manufactured by Rubery Owen. When legislation changed the lift up axles were removed.
The R and H Kenworth photo by Vaughn Mills .
Time to create page: 0.505 seconds
