- Thank you received: 4809
Tri-axle trailers with singles on front axle
- Mrsmackpaul
2 years 7 months ago #226702
Replied by Mrsmackpaul on topic Tri-axle trailers with singles on front axle
looks like the spider on the flat top is a normal spider with a spacer on the outside ?
2 years 7 months ago #226705
Replied by hayseed on topic Tri-axle trailers with singles on front axle
My Memories of those single tyre Silly wheel pusher Axles, Is..
In the early 70's when Triaxle trailers were allowed People started fitting them to existing Trailers to get the Extra Weight. .By the Late 70's The Govt mandated they had use Load sharing Suspension(As well as Brakes), Because as Xspannerman said a lot of them had Airbags & blokes could Manipulate the old split weigh Weighbridges with them..
But Don't mind being Corrected..
2 years 7 months ago #226706
by jeffo
Replied by jeffo on topic Tri-axle trailers with singles on front axle
Hard to imagine now Paul, but in the 60's and early 70's the dolly steer axle wasn't permitted brakes.
Not sure if that applied to tandem dollies but was certainly the case with single axle jobs which were pretty common back then.
I'm still amazed when thinking back to the petrol KL Bedfords of Luya Julius with 1-sugar bin on the truck and towing a short dog with 2-sugar bins. Only brakes on the whole show were the pathetic vacuum/hydraulics on the 7t Bedford and 7" vacuum mechanical on the rear axle of the dog.
28 ton gross too.
28 ton gross too.
2 years 7 months ago #226712
by PaulFH
Replied by PaulFH on topic Tri-axle trailers with singles on front axle
Thanks XSPANRMAN, that's the one I saw on FB, fitted to a flat top trailer.
Think it was an ongoing push to get more payload within the regulations of the
day, at minimum cost. Tried on prime movers and trailers in differing ways.
Quite a number of bogie trailers extended and converted to tri-axles late 1970's.
Better set up, as load share suspension and brakes. Just from memory, Paul.
- Mrsmackpaul
2 years 7 months ago #226718
Seed I dont think the tippers shown were ever bogies as the mud guard is full length and it looks to me like these were built this way
Either way it is all very interesting to me and amazing how much of this stuff we have forgotten already
Jeffo, I cn honestly say I have never seen a single axle dolly with out brakes, mind you I wouldn't of worried about looking unless I had a reason to
2 years 7 months ago - 2 years 7 months ago #226720
by Gryphon
Replied by Gryphon on topic Tri-axle trailers with singles on front axle
Hi,
is this another one?
It was posted up in Overlanders Old Photos a day or so after the picture that started this thread, www.hcvc.com.au/forum/OldTruck/16820-ove...tos?start=870#226433
Terry
Terry
Last edit: 2 years 7 months ago by Gryphon.
2 years 7 months ago #226721
Jeffo, Dad had a Similar Setup.
Only His was an Inter AB160 tipper towing a 16foot Dog Trailer Carting Grain. Trailer had Vacuum over Hydraulic Brakes on the back axle only. No Brakes on the Dolly, From memory the axle in the Dolly was the back axle out of an Old Blitz with axles & centre removed. we were still using it up until the mid 80's..
28 ton gross too.
- Mrsmackpaul
9 months 1 week ago #247118
I come across photos on social media every so often of these unusual axle setups
Can never find this thread/topic, at 4 am and nothing better to do with my life I eventually found it ha ha ha
Not my photo and not real sure who's it is but guessing person mentioned in the blurb attached
Coal truck, Camden.
Brown double wheeled semi-trailer used for carting coal to the rail head. Owned by Barry Doust. Not photographed in Camden, perhaps at Oakdale.
Photo c. 1970, contributed by Mrs Jean Doust.
From Camden Images Past and Present.
© Camden Historical Society.
Coal truck, Camden.
9 months 1 week ago #247137
by Brocky45
Replied by Brocky45 on topic Tri-axle trailers with singles on front axle
The set up shown in that last picture is similar to what we have up here in the States with a single tire on the third axle. A lot of our third axles were to beat the "Bridge Law" .. I was never involved in that type of work, but apparently the third axle allowed a larger gross weight on a shorter trailer..
9 months 1 week ago #247146
Replied by JOHN.K. on topic Tri-axle trailers with singles on front axle
The ones I fitted ,there were air bags to apply weight to the axle ,and generally inverted springs to lift it off the road ........these setups used to rip tyres to shreds,so you only used busted cases not fit for retread......The wheels had to be in contact with the road ,as the scalies would take pictures before stopping the truck.....So there had to be some load on the axle .
Time to create page: 0.585 seconds
