Avatar Q:?
8 years 7 months ago #162873
Avatar Q:? was created by Swishy
Wot b the max size of avatar
Length n Width in pixels & kb size
also can eye have an animation (az in GIF) if size iz not exceeded
aslo wot about signiture etc
Thanx in advance
Thanx in advance
8 years 7 months ago #162879
by Gryphon
Replied by Gryphon on topic Avatar Q:?
Hi,
The filesize of the Avatar is set to a max. of 100kb which is plenty for a little image, however people who got their avatars up early were able to load up 250kb.
There is no width/height restrictions as the system will try its best to fit the image in the area available which may change depending on the particular device you are using. If you have an image with an extreme width or height you might find it will look a bit deformed in some cases so closer to a square or 4:3 the better.
No restrictions on animated .GIFs I can see.
Signatures also have no restrictions built into the software so we would be relying on people to be considerate and not take up too much space or other members might start hitting you with a big stick if your siggy is annoying.
During testing I did a a bit of customisation working with one of Sarge's images in his signature to automatically resize images and create a max. height but I haven't recreated that yet in the live version, so just on the to do list.
Terry
Terry
8 years 7 months ago #162978
by Crashbox
Enjoy life. It has an expiry date!!
Replied by Crashbox on topic Avatar Q:?
Hi all,
Like the new look, change is good. Particularly when it's for the better.
I must of blown a fuse somewhere, can't locate the specifics.
Can someone tune me up re posting an avatar??
8 years 7 months ago #162982
Replied by Swishy on topic Avatar Q:?
CrashBox
up top click on u're PROFILE
then clik EDIT ( small Blu write n on right)
then clik on sum gray write n
User Account ....... Profile Information ....... Avatar Image ....... Forum Settings
n u're there
n u're there
- Thank you received: 4848
8 years 7 months ago #163030
I wouldnt worry to much I never found out how to avatar on the old forum I might give it a bash on this one LOL
Replied by Mrsmackpaul on topic Avatar Q:?
Crashbox wrote: Hi all,
8 years 7 months ago #163060
by Mairjimmy
Come on Paul Crashbox done it, it's up to you now to do it, we want to see something "Flashy" :ohmy: :ohmy:
Colin
Replied by Mairjimmy on topic Avatar Q:?
Colin
8 years 7 months ago #163070
by tim
Replied by tim on topic Avatar Q:?
I had an Avatar but it's gone awol since the new forum started. Can I retrieve it or do I have to redo it?. Can't remember how I did the original one come to think of it. Cya Tim :whistle:
8 years 7 months ago - 8 years 7 months ago #163074
by Mairjimmy
Come on Tim, get that grey matter working and get your profile up here. And then your avatar up here, the white KW cab over will do . Easy enough , hit profile, then edit, do what ever there and profile imformation and then hit avatar and follow instructions
Colin
PS dead easy as I could do it. :huh:
Colin
Last edit: 8 years 7 months ago by Mairjimmy. Reason: to add a couple of words
