- Thank you received: 50
Mig Welding Gas sheilding or Gasless
2 years 6 months ago #227584
by tim
Mig Welding Gas sheilding or Gasless was created by tim
Hi everyone, need a few views on the pro's & con's of Gasless or Gas sheilding with Mig welders.
I have never used the Gasless type of mig wire, but have recently read that gasless is better for outdoor welding as it is not affected by the wind. I realise that we can put up wind screening to cover the problem but wondered what other people have found with their experiences. Thanks in advance, Cheers Tim
2 years 6 months ago #227590
Replied by Dave_64 on topic Mig Welding Gas sheilding or Gasless
Tim,
be the last bloke to give anyone any welding advice, but I do the majority of my Mig welding with
Gasless!
Have found that I have to be scrupulously clean when welding, no paint, no rust, no galvinising, if not seem to get a lot of slag.
No doubt lot of far better welders on here than I, some will no doubt tell you they get equally as good a weld with a stick welder.
Dave_64
Gasless!
Dave_64
The following user(s) said Thank You: tim
2 years 6 months ago #227593
by tim
Replied by tim on topic Mig Welding Gas sheilding or Gasless
Hi Dave, thanks for the reply, I had a Gas shielded Mig but gave it to my son when he left home & now I find things that I need to weld & can't do it when I want to do it. Not his fault because he's working for a living & I'm retired so it's frustrating. The thought behind the Gasless idea is that there is no gas bottles to organise or rent, Cheers Tim
- Thank you received: 286
2 years 6 months ago - 2 years 6 months ago #227596
by 77louie400
Replied by 77louie400 on topic Mig Welding Gas sheilding or Gasless
Welding is a part of my business, get a good 3 in one Stick, Mig and Tig buy the gas bottle outright and you can run Gasless when you don't want too carry the bottle, I have a little Stick that fits under the seat of the ute that will run 2.5mm rods all day, paid about $200 I use it as much as anything on fiddle ass type construction site work, a good mig on gas is hard to beat, look after it and keep spotless your gun and tube clean it, clean it, clean it
Last edit: 2 years 6 months ago by 77louie400.
2 years 6 months ago #227598
by 600Dodge
Replied by 600Dodge on topic Mig Welding Gas sheilding or Gasless
Gasless mig is absolute garbage, I can't think of a single use for it, if you are worried about the gas bottle you would be better off with the CIG microarc and a box of 1.6mm rods.
- Thank you received: 4783
2 years 6 months ago - 2 years 6 months ago #227601
Replied by Mrsmackpaul on topic Mig Welding Gas sheilding or Gasless
I bought myself a inverter suit case stick welder, CIG weld, when it worked it was okay,, problem is CIG wont fix these and carry zero parts or service when the warranty is out of date you are high and dry
It went ka put and was only good for scrap and land fill
it cost I think 400 bucks
Next off the list was Lincoln that was about the same specs but cost a bit over a grand, Lincoln told me they carry parts and will always fix it
so far it is head and shoulders above the CIG weld rubbish, put it on full power and just feed the rods in, it never over heats and never fails
It has a TIG feature but, try as I may I cant TIG to save myself
Also got a UNI MIG and after getting to know it Im pretty impressed with it and what I can do
and no gas less MIG, have tried it on a mates welder and gotta agree with previous post, waste of money
Last edit: 2 years 6 months ago by Mrsmackpaul.
2 years 6 months ago #227608
Replied by cobbadog on topic Mig Welding Gas sheilding or Gasless
If you decide to go with gas as suggested buy a bottle outright and then you only buy the gas. Another option I took was at Bunnings. $100 gets you a bottle of gas and then you keep swapping the bottles over each refill and no rental. Since I went this way I have heard that the buying outright of a bottle can be cheaper in certain areas.
With that said when we get back from this eye operation for Dee I will be having a more serious attempt at gasless welding. In the past pidgeon poop wa far better looking and possibly stronger but I have been getting some tips and again as already mentioned, preparation is key then it is all about the settings. Some have claim nice smooth welds as if it was done with gas. So I will persist for a while to see how it goes otherwise the gas bottle will get dragged out to do the job.
I dont know if there is good and bad quality flux cored wire so I will follow up on that as well. Some have the flux core plus some ironised coating on the outside as well. So many options for a novice to try and take in.
2 years 6 months ago - 2 years 6 months ago #227612
Replied by PDU on topic Mig Welding Gas sheilding or Gasless
My (pathetic) personal experience with gasless mig was an absolute failure and is the reason why Ernie comes on board with his gas mig. We probably would both admit that his welding has improved while working on B for.
Up until Ernie's arrival on the scene I have done everything with my old stick welder, bought about forty years ago, but having seen those neat little inverter welders am tempted to buy one. Other than the cost of the gas, and having to rely on somebody else, I will stick with Ernie for now . . . he looked genuinely pleased with the progress we have made when the top curved pieces went on last Monday. Have to check how he went with possible stents yesterday . . . hopefully all okay.
Last edit: 2 years 6 months ago by PDU.
- Thank you received: 1174
2 years 6 months ago - 2 years 6 months ago #227646
by Southbound
Replied by Southbound on topic Mig Welding Gas sheilding or Gasless
I have a good MIG welder from when I was self employed, nowadays it only gets used when I have a project. ATM BOC have the best deal on MIG gas at $108 per year for one bottle including gas. In the past I found CIG/BOC to be a terrible company to deal with, but now, the low price suits my needs.
Last edit: 2 years 6 months ago by Southbound.
2 years 6 months ago #227649
Yep I Agree 100%.. they had rape & Pillage down to a Fine Art...!!
Amazing what a bit of Competition Does..
Replied by hayseed on topic Mig Welding Gas sheilding or Gasless
Time to create page: 0.509 seconds
