8 years 1 month ago #168678
Replied by Swishy on topic International A40 - 1 Superloader
Sarge :-X
Th@ bottom pic
Is th@ your hair U been pulling out
:lol:
eye feel your pain
Just 2 B different to get another view of the culprik
may B take the Bridgstone n rim off of beast
or am eye miss n the point ?
Th@ bottom pic
:lol:
eye feel your pain
- Thank you received: 4815
8 years 1 month ago #168689
Replied by Mrsmackpaul on topic International A40 - 1 Superloader
dumb question time from dumber farmer in north QLD what are the two bolts on the out side of the puller screwed into ????
The following user(s) said Thank You: ianoz
8 years 1 month ago #168690
by wouldyou
Replied by wouldyou on topic International A40 - 1 Superloader
Sarge,
As with Mrsmack I can't see what the outer puller bolts are fixed to, are they hooked behind the wedges?
Can you get a threaded rod or long bolt to screw in to the axle through a plate pressing on the cast wheel centre as you now have. The puller would not be needed, the plate would have to be heavier or reinforced as the one in your photo would easily bend.
Cheers, David.
Cheers, David.
8 years 1 month ago #168710
Replied by Sarge on topic International A40 - 1 Superloader
The two bolts in the wedges are only half started in as someone said I needed them to stop the wedge flying out and cracking me in the knee cap... they have 10/15 mm clearance...
And the two bolts or arms on the puller are hooked behind the wedges, there is a 8 or 10 mm gap behind the wedge.
David, I have been a bit reluctant to risk damage to the thread in the axle, I can buy my mate a new puller if i bugger that. and yes I need to reinforce the plate, it has a bend already.
Swishy the hair is mine, from banging my head against what should be easy but turns out to be almost impossible.
8 years 1 month ago #168712
by ozfarm
Replied by ozfarm on topic International A40 - 1 Superloader
one little suggestion i could make,
find someone who has a puller set up to remove the rear hubs off a case LA,500,830,900,930 , case used a tapered hub they have apuller thread of 2" dia,
tap them bolt holes out to a thread size u can get
do it up tight, then give the thread bit a rather good whack on the end with a BFH and then retighten
methinks u aint gunna do any good trying to push the wheel centre in, cos the wedges are meant to be removed
8 years 1 month ago #168713
fun times a plenty Sarge you'll get there Im sure of that I have one more idea if you have no luck with what your doing only problem is its a lot more work
Hang I just had another thought hmmm shouldnt that Paul you will strain the peanut of brain
If you know anyone with Cat dozers they need big pullers up to a hundred ton to pull and push the sprockets on dozers so if you know of anyone close by with Cats maybe give them a call and they might know who has the pulling gear in your area
If that doesnt work I have a fail proof or maybe thats fool proof plan LOL
8 years 1 month ago #168714
by wouldyou
Sarge,
An armchair expert here.
Stiffening the plate to make it rigid is the way to go
Ozfarm, when pulling on the wedge there is friction on both sides, if the hub can be pressed in a bit it eases the pressure on the splines, as you say tapping the holes next size up would be the way to go and the studs will force the hub in as intended.
David.
David.
7 years 10 months ago #171262
Well, max the expert was here today, he had a bigger puller, you know the one with the grease piston in the centre, it is of heavier construction than the one I was using, rated about 10 ton... so Max screwed and I slammed the cast wheel centre with the 11/2 inch 15 kilo solid bar, almost playing tubular bells :lol: , end result, as you would expect, nothing. Well not quite nothing, we did strip the push bolt hole on one side, so worse off now than when I started, might end up with forearms like Popeye's if I have to keep slamming the bar. :dry: :dry: not a good look in a skinny ninny.
Max will see a bloke about a short ram for his power pack, then we think we will tap out all the holes in the wedges, so we can bolt a plate to the wedges with the ram in between, pushing on the axle end, should get more than 10 ton going that way.
:blink: I a, calling this progress.... we have done something that needed to be done, so we can do something different next time. Max has identified the wedges as being very long,and rusted in so not likely to respond to a hard hit. :blush:
David, I think the power pack will work as you described with the threaded rod. Thanks.
7 years 9 months ago #173449
by Bluey60
Replied by Bluey60 on topic International A40 - 1 Superloader
Hi Sarge
I take it you haven't felt the earth move just a thought if you can tap the push
holes a size bigger as well as the porter power it will give the wheel centre a push
back off the taper of the wedges only thing you won't get the thread right through
so you will have to grind/turn the ends of the bolts that you use to push with
down so they will go through the end of the hole with no thread I'd say you would
need at least 1" without thread
THEN get as much pressure on the puller the pushing bolts belt hell out of everything
then still with all the pressure on start the old girl up and tear off across the paddock
as fast as it will go and shake the shite out of it
Bluey
Bluey
7 years 9 months ago - 7 years 9 months ago #173455
Replied by Lang on topic International A40 - 1 Superloader
I am finding this an interesting thread not because of the job in hand but the fact we have many experts on the forum ranging from degree holding engineers to apprentice mechanics and none have come up with an ingenious technical solution. The never say die cockies are working together on the get a bigger hammer principle and are not going to let the bastard beat them. I am sure you blokes will get that fitting off soon.
Just had a look on a boat forum with people talking about getting a prop off. While not exactly the same as your problem there are some real gems of ideas that could be applied to your situation. Have a read right through all the responses, there are some very experienced and smart blokes on there along with the usual keen advisers.
forum.woodenboat.com/showthread.php?1547...rick-to-pulling-prop
Here is a discussion by some Yanks with similar problem on old tractors - might be some clues for you.
www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=jd&th=220966
Last edit: 7 years 9 months ago by Lang.
