1949 Bedford engine rebuild
- Thank you received: 4822
- Thank you received: 839
Thinking thinking But cant recall, is the dizzy all all the way home to engauge the drive tang ? .....
I had a recon oil pump once that had the wrong gears in it, just a bit short but enough to make it not pump
...Billy
I used to be a truck driver,
on a good day i can remember
not knowing nothing about bedfords is the dizzy driven off the same shaft as the oil pump? If so pull the dizzy out and make a shaft the same as the bottom of the dizzy and put a drill on it and give it a spin see if it pumps oil at all dont no if it will work
This is a great idea, just make sure the drill is spinning the the correct way Ie in the direction of rotation of the oil pump or you will just be blowing air bubbles into the sump.
harpo
d.l.marks&&( harpo)&& on&&LA SNAIL -(69 beddie)&&&
- Thank you received: 5
It sounds as if you didn't prime the oil pump. It also sounds as if the engine has been spun over for quite some time with no oil pressure. Only safe way to proceed is to drop the sump and inspect the bearings.
please forgive my youthful ignorance but doesn't the oil pump normally drive off the bottom of the dizzy which drives off the gear on the bottom of the dizzy to the cam shaft ? So if you have an old dizzy you can pull the shaft out of knock the roll pin out slide the gear off then it will only drive the oil pump because there is no gear to drive to the cam shaft but I guess its like I have said before I dont no nothing about bedfords so am properbly wrong :-[Can't see you being able to turn the engine over via the distributor drive - because that's what you will be trying to do.
So to turn the oil pump, you would have to turn the engine over, and it would not be feasible to do this using the distributor drive.
Beaver@ Museum of Fire
