- Thank you received: 257
Removing rust and scale
7 years 10 months ago #171110
by 600Dodge
Replied by 600Dodge on topic Removing rust and scale
Be very, very careful with phosphoric acid, it is dangerous with a capital D, if you get it on your skin it can leach into your bones and its bye bye.
The following user(s) said Thank You: hayseed
7 years 10 months ago #171111
Replied by hayseed on topic Removing rust and scale
Good advice 600Dodge.
- Thank you received: 546
7 years 10 months ago #171112
Replied by Blackduck59 on topic Removing rust and scale
600 Dodge, think you maybe thinking of hydroflouric acid. That heads to the bones and you need a license to purchase and handle it..
Any acid can be dangerous, read all the MSDS and have the right neutralizing agent handy
7 years 10 months ago #171140
by mikeg
Replied by mikeg on topic Removing rust and scale
Jim
Steel, spring steel or iron is OK with this system but NEVER aluminum or alloys, I tried it and it will eat the alloy.
Mike
Mike
7 years 10 months ago #171146
by 600Dodge
Right you are Blackduck, I just had a look at the msds sheets and hyrofluric is the nasty one, phosphoric is relatively nice.
7 years 10 months ago #171151
by wombat 46
Replied by wombat 46 on topic Removing rust and scale
I think it is a good warning though never treat any acids or unknowns without caution
Thanks for all the advise
I hope to get a large plastic drum today
Raining here alot over the weekend so will see what happens
Jim
Jim
7 years 10 months ago #171167
by wombat 46
A few pics from today,
i had all the PPE and was outdoors
I started with a mix of 5 parts water to 1 part acid, i then added a little more acid as i had the bucket full of rusted metal parts
The bubbles were visible from the rust on the metal surface
Some parts i had that have been sitting for a long time waiting treatment
Jim
Jim
7 years 10 months ago #171168
by wombat 46
As i was trying to see the process in action, and learn a bit
i dipped a small part part way and took photos every hour
The only mistake i may have made was i washed the parts in the parts washer to remove any dirt and grease. I probably should have de greased them to remove the diesel residue first.
After 1 hour
2 Hours
3 Hours
4 Hours
Jim
After 1 hour
2 Hours
3 Hours
4 Hours
Jim
7 years 10 months ago #171191
by mikeg
Jim have you skipped the first step, the caustic and battery charger part? It's that first step that does all the work and gets rid of the rust/paint/grease etc and the phosphoric is really just to neutralise the caustic and put a coating on the parts to prevent rust etc. I doubt whether the phosphoric alone will do the job.
Mike
Mike
7 years 10 months ago #171193
Replied by Swishy on topic Removing rust and scale
Time to create page: 0.637 seconds
