Dodge 1965 AT4 tow truck
7 years 2 months ago #179900 by Swishy
Replied by Swishy on topic Dodge 1965 AT4 tow truck
DodgyChem
RE: https://www.hcvc.com.au/forum/attachment/4012
not sure ifn U kno wot the switch iz about..... but here goes
if the switch iz the same as Inter
U turn/twist the contol knob n either activates the interior dimmer light or background dash light on dimmer
one notch out = side or parker lights
2nd notch out also adds headlights via dipper switch on floor
Butt
There again
WaddaEyeKno
:lol:
7 years 2 months ago #179909 by DodgeyChem
Replied by DodgeyChem on topic Dodge 1965 AT4 tow truck
Thanks Buddy!!
I'm cool with the light switch as a user.....I was just taken aback by the bimetallic strip/ignition points looking gizmos on either side.
Maybe they are there rather than fuses??!! :ohmy:
Definitely some room for improvement on the wiring safety side :sick:
I see my future .......... under the dash :silly:
7 years 2 months ago #179915 by 600Dodge
Replied by 600Dodge on topic Dodge 1965 AT4 tow truck
So your future isn't under the dash, if you do any rewiring make everything pluggable, use duetsch plugs on everything so if something goes wrong you can remove the dash by unplugging all the wiring and the only hard bit will be unhooking the speedo cable, and of course make sure all new wiring follows the colour codes in the manual so it is easier to fault find and leave plenty of length so you aren't peering through a little gap because you can't pull the dash out far enough.
7 years 2 months ago #179916 by asw120
Replied by asw120 on topic Dodge 1965 AT4 tow truck
DodgeyChem wrote: Thanks Buddy!!
Yep, they is circuit breakers. The one on my Dad's Stude Lark used to trip every time you went over 55 mph with high beam on........(the voltage reg was set too high)
7 years 2 months ago #179917 by DodgeyChem
Thanks!
I just finished doing the wiring from scratch on my hot rod (52 Ford F1), but had to change course to get this Dodge up and running to be my new company delivery truck!@! :woohoo:
It's such a different job between doing an all out hot rod job, replacing brand new bits with others that have more chrome, compared to the functional rebuild I'm doing now for the Dodge everyday workhorse.......which I guess was always the real attraction of these Aussie-built beasts of burden, built just 10 kms down the road from where I'm sitting now. :cheer:
7 years 1 month ago #181191 by DodgeyChem
Hi All,
the recommissioning is going well, and I've even been driving the old girl around the last few days!!!
Good Times!!!
7 years 1 month ago - 7 years 1 month ago #181192 by DodgeyChem
.....BTW......
I got in touch with the original owner, and he chatted to me for a half hour on the blower, then sent me this.......
Last edit: 7 years 1 month ago by DodgeyChem.
The following user(s) said Thank You: trucksyd, tim
7 years 1 month ago #181218 by asw120
I could probably find out where that Studebaker is now.....(was never many about)
7 years 4 weeks ago #181791 by DodgeyChem
The rear end locked up on me on the way to the brake shop.
Diagnosed wisely as a stuck gearbox...... :sick:
I left it with them to do the brakes anyway.....
I went to the wrecking yard planning to wrestle a NP435 out of one of the trucks there, single handed, no jacks allowed...... :silly: .... :sick:
At the wrecking yard they had a very clean XF ute.....for cheap.....I own it now......and it's a ripper....
This left me with time to wait for a good solution for the poor old Dodge.
In true lemonade from sour apples fashion, a Dodge AT4 318 with NP540 gearbox popped up on gumtree today, and only 100kays away from home.
I just got back, heavy bloody 318 and box in the back of the ute, and a couple of Mopar savvy mates are gonna help me do a one day engine swap in the coming week or two.
Yeeeee Haaaarrrrrr !!!!!!!!!!!!!!! :woohoo: :evil: :whistle: :woohoo: B)
7 years 3 weeks ago #181807 by IHScout
Replied by IHScout on topic Dodge 1965 AT4 tow truck
Well done. The poor old ute must have been dragging it's backside on the ground all the way home :lol:
Dennis
Time to create page: 0.471 seconds
