- Thank you received: 257
Best aggressive coolant flush for Chev blitz
7 years 1 month ago #181373
by 600Dodge
Replied by 600Dodge on topic Best aggressive coolant flush for Chev blitz
It would be a bit useless to use the vacuum gauge if the engine wasn't running.
7 years 1 month ago #181383
Replied by Sarge on topic Best aggressive coolant flush for Chev blitz
we have done 9 pages on cooling the critter down,
how many pages can we get on checking the timing with the engine shut down using a vacum gauge....
we gunna set a record???? :silly: :silly: :silly: :silly:
Wedge, ya know we cant let this go now, we need you to solve this for all our collective sanity.
Good luck, keep us informed.
7 years 1 month ago #181475
by grahamjb
Replied by grahamjb on topic Best aggressive coolant flush for Chev blitz
Going back to the original question about something to flush the block with.....no guarantees with this solution but fill it up with CLR and run the engine until it gets hot each day and do this for a week. Drain out the CLR, flush with water and then fill with 50/50 water/citric acid mix and repeat as for the CLR. Drain and thoroughly flush, fill with water , cross your fingers and let everyone know if it fixed the problem.
- wedgetail84
- Thank you received: 49
7 years 1 month ago #181493
by wedgetail84
Replied by wedgetail84 on topic Best aggressive coolant flush for Chev blitz
lol, I assume blackduck was meaning the vac test is a better test overall but it needs to be running to do it? Either way, maybe timing's a bit out one way or another, but it's certainly not stopping coolant flow which is the underlying issue.
Sarge - if you guys can solve this for me I'll happily read through what ever it takes! I do have a vac gauge, and I don't doubt it will tell me a lot, but like I said it's not going to diagnose a coolant flow issue! Graham - what's CLR?
I know I'm stringing this out a fair bit without physically doing anything I'm just trying to juggle a few different activities and this isn't top priority. Besides, there's some good info emerging in this thread!
7 years 1 month ago #181502
by grahamjb
Wedgetail
You can buy CLR from Coles/Woolworths/IGA etc
CLR is a household cleaning product used for dissolving stains, such as calcium, lime, and iron oxide deposits. Its ingredients include water, lactic acid, gluconic acid, lauramine oxide, Propylene Glycol, n-Butyl Ether, and solvents that dissolve cobalt gel coats and paint.
