- Thank you received: 1104
1971 White 7564TD
The basic truck is solid and goes well. I don't intend to do any major work to it, just tidy it up a bit. It has a lot of little things that don't work, like auxiliary gauges. As I know SFA about heavy trucks, I will be asking some questions which may cause some to roll their eyes; please bear with me as I familiarise myself with it.
I did get some pictures of it from back in the day, which I will post later.
There appears to be four water senders! I'm guessing one low level (on header tank), one temp. gauge (on thermostat housing, I think)
and these two.
Thanks, Jarrod.
- Thank you received: 4758
I'm sure there's plenty of Cummins experts on here that can give you the low down on what's what
At a guess water temp , water level and maybe something for shutters on the radiator
That patch on the intake is fraught with danger- if the back of those rivets break off, they will go into the turbo and maybe further. I would either replace the pipe, or remove the patch and slide a piece of hose over it with a couple of hose clamps.
Also made cross members for old mate up in Toowoomba.
Long time ago though.
dieseldog wrote: Generally speaking, senders have one wire and switches have two. The switches could be for a Murphy or a warning light. If they are VDO, they will still be available new. You just have to buff them up to read the part number.
Thanks for that. A bit of hose might be the go for the intake, then. Although, I believe it has done many tens of thousands like that. Something to remove and check, anyway. Hose would be easy.
Wires are not easy to trace on this, so I will have to disconnect & or short a few things out to see what happens.
