Air conditioning for the older trucks
5 years 3 months ago - 5 years 3 months ago #198063
by Mairjimmy
Replied by Mairjimmy on topic Air conditioning for the older trucks
Last edit: 5 years 3 months ago by Mairjimmy. Reason: to add a couple of words
The following user(s) said Thank You: cobbadog, Southbound
5 years 3 months ago #198084
by 600Dodge
Replied by 600Dodge on topic Air conditioning for the older trucks
I wouldn't be too keen on those clamps, or be sure of their legality as far as ARC is concerned and I wouldn't be at all surprised if you had trouble finding someone to gas it. If I was in this position I would probably try to buy the kit minus hoses and mount all the components then pay someone to supply/make/fit the hosing and then gas it, it probably wouldn't be much more expensive.
- Thank you received: 34
5 years 3 months ago #198113
by mercskeepmeinajob
Replied by mercskeepmeinajob on topic Air conditioning for the older trucks
These Atco Air o Crimps are fine and meet Au Standards so long as the hose, fittings and crimpers are used. Makes the older style Atco crimper I've got, made redundant, another $800 down the drain.
5 years 3 months ago #198122
Replied by cobbadog on topic Air conditioning for the older trucks
I received a quote from AER today confirming price for the 24v system delivered and was just under $2200.00. Then plus gasing which will not be a problem as I have already asked the local bloke if he would do it and if the crimped hosing was ok and he has no issues with it at all.
So I can will take Lorry into town for him to confirm that the kit will be ok for install.
5 years 3 months ago #198232
The AER system is still high on the list but a mate claims that the Dometic RTX 2000 will be a better option. Big problem as far as I can tell is that the Dometic is called a ''parking cooler" only and some say is only for when your parked up and not to be used when driving along the road. It is a totally self contained unit all in a box and only requires a 24v power source to be operational. A price for the Dometic is around $2560.00
5 years 3 months ago #198246
by Mairjimmy
Did your mate know of the unit been used while mobile he be your best bet to quiz about it l haven't heard or seen them other than just Googled it now, might be a goer but you would need to examine it a bit further
5 years 3 months ago #198264
Yes he was in contact with a bloke from Pearsons Transport who are supposed to be installing them.
Another supplier is Webasto or Webasco and also Red Dot which is a Webasto unit modified for the earth moving industry.
Hopefully he will chase up Dometic this week to confirm its use as being a completelyt self contained unit there will be minimal loss of HP when running as opposed to running a compressor off the engine. I do realise that some loss of power may occur from the drag of electricity. Approximate draw of power is 8.5 amps from memory.
5 years 3 months ago - 5 years 3 months ago #198266
by Eddy
My lil' Terrier touched 130 overtaking a muppet towin a caravan. Bartsage had insisted on accelerating ever time I tried to overtake and then drop back to 85-90 when I backed off.
Waited my time 'til we got to a spot I knew would work, got a bit of a run up from 1/2 a km behind, and went past him like he was standing still.
:evil: (Then dropped back and gave him 10 kms of his own medicine) :whistle:
Checked back through the GPS trip comp and showed max speed of 129.6 for 1.3 kms.
.... oh ...
and ...
I have an old underdash unit near ready to final fit. Biggest hassle is finding somewhere to hang the compressor. Normal spot in the car version of this engine is occupied by the air compressor for brakes.
Replied by Eddy on topic Air conditioning for the older trucks
yep! ... MPH even ...Swishy wrote: Can a Leyland get to 60
.... oh ...
and ...
Last edit: 5 years 3 months ago by Eddy.
5 years 3 months ago #198273
by 600Dodge
Ive fitted those dometics to underground refuge chambers, they are pretty weak, need a pretty large hole to mount the unit through a panel and need a pretty hefty amperage 24V supply.
4 months 3 weeks ago #249564
by Bluey60
Replied by Bluey60 on topic Air conditioning for the older trucks
Hi All
Looking to rebuild/retrofit the air conditioner in a Deutz tractor was thinking one of the underdash units would work the current evaporator unit sits on top of the dash thought I could fit one into the same housing
Just wondering if anyone has fitted one and how they performed
Cheers Bluey
Cheers Bluey
Time to create page: 0.548 seconds
