- Thank you received: 313
1934 International C1
10 months 14 hours ago #246925
by Inter-Action
Replied by Inter-Action on topic 1934 International C1
I am going to try some carpet under lay , under the floor mat. The carpet people are always throwing it out. May be a bit thick but worth a try??
Also. On the door cards ,i would be gluing a circle of foam around the door handle and window winder. They tend to chatter ,
if there is not a little pressure from behind.
My thoughts. Dave.
My thoughts. Dave.
10 months 13 hours ago - 10 months 12 hours ago #246926
Replied by Lang on topic 1934 International C1
I have been using this stuff for years from Bunnings. Same sort of thing as Dynamat but half the price.
It has a very sticky soft rubberised layer about 3mm thick covered with shiny aluminium foil. Sticks to everything, is waterproof and does not hold moisture like underlays and foam. Noise cancelling , stops panel drumming and heat insulation barrier. It is structurally sound enough to cover all those mysterious holes through the firewall old vehicles seem to collect up to about a 100mm diameter either back, front or both. It does not come unstuck with heat if you put it on the engine side.
It comes in various widths and lengths. I find it nice to work with like Dynamat as you can cut out your required shapes and holes before removing the backing layer
Last edit: 10 months 12 hours ago by Lang.
The following user(s) said Thank You: 180wannabe, cobbadog, Morris, 77louie400, PaulFH, asw120, wee-allis, PDU, lemmiwinks
10 months 2 hours ago #246936
Replied by cobbadog on topic 1934 International C1
I used it when I did the door cards on Lorry. Bought the spnge foam from a local foam/rubber shop.
- Southbound
- Thank you received: 1192
9 months 2 weeks ago - 9 months 2 weeks ago #247211
by Southbound
Replied by Southbound on topic 1934 International C1
I spent a lot of time on the fuel gauge sender unit and it wasn’t 100% so just kept going on with other jobs and thinking about a solution.
I have since found out that a MF135 sender is the same, beauty. They are available new, made in India, $50 and 6 weeks delivery.
Works well on 6 volt (don’t ask lol) but works backwards. I was going to bend the float rod to the opposite side except there’s a baffle in the fuel tank. Looking at the resister and realised if I moved the
gauge wire to the opposite side it would do what I needed, so did that. Next shorten the float rod to suit the depth of my tank. Then make and solder in a pickup line.
Then put it all back together and test, all working perfect now.
Last edit: 9 months 2 weeks ago by Southbound.
The following user(s) said Thank You: 180wannabe, cobbadog, PaulFH, asw120, wee-allis, oliver1950, theabundantlife, lemmiwinks
- Southbound
9 months 6 hours ago - 9 months 6 hours ago #247518
by Southbound
Floor mat and boots in now.
Interior finished now. I really like these pressed metal covers that go on top of the door trims. Also cut, stain and fit new Tassie Oak trim around 3 windows.
Last edit: 9 months 6 hours ago by Southbound.
- Southbound
9 months 6 hours ago - 9 months 6 hours ago #247519
by Southbound
I was lucky to find this little badge in amongst the parts to give credit to Alf Mitchell, so mounted it front and centre.
No it’s not on the p1ss, just the amateur photographer lol.
So now just fixing all the teething problems as we go along. CPS soon, fingers crossed.
The following user(s) said Thank You: 180wannabe, cobbadog, Lang, PaulFH, asw120, grandad, Tacho, wee-allis, oliver1950, lemmiwinks
9 months 5 hours ago #247521
Replied by hayseed on topic 1934 International C1
Very Nice Southbound.. Won't be long now & you'll have a Plates on It & out enjoying the fruits of your Labour..
OK, It's dumb Question Time...LOL
What is the second dipper switch for..?? (maybe the Starter)
https://www.hcvc.com.au/forum/attachment/40751
9 months 5 hours ago #247523
Replied by asw120 on topic 1934 International C1
Those really are one of the nicest looking vintage utes.
- Southbound
9 months 3 hours ago - 9 months 3 hours ago #247524
by Southbound
Hayseed Yes, it's the starter button. It works and it gives the 30's feel so I kept it.
Last edit: 9 months 3 hours ago by Southbound.
- Southbound
8 months 4 weeks ago #247534
by Southbound
The mirrors were another challenge, these are modified motorcycle mirrors screwed into the wooden door frames.
The following user(s) said Thank You: Sarge, 180wannabe, cobbadog, Morris, PaulFH, wee-allis, oliver1950, theabundantlife
Time to create page: 0.511 seconds
