- Thank you received: 3
Dodge AT4 D5N International AA AB vent window seals
3 years 10 months ago #212774
by soops
Replied by soops on topic Dodge AT4 D5N International AA AB vent window seals
Top and bottom are both fine, it's just the forward edge that's the problem.
It's as if the window isn't wide enough to fill the hole - but nothing has been changed. Same window, same frame, same door.
The frame is held into the door by four screws - top, bottom and two on the forward edge.
The frame is supported by 'pads' that are welded into the door. The position of these 'pads' dictate the shape of the frame. If the frame was grossly out of shape it wouldn't fit into the door and the screw holes wouldn't line up.
It's got me .........ed.
- Thank you received: 4886
3 years 10 months ago #212794
Replied by Mrsmackpaul on topic Dodge AT4 D5N International AA AB vent window seals
In this picture it looks like it is making the distance at the lower end on vertical piece of rubber
Might be just camera angle
3 years 10 months ago #212833
Replied by cobbadog on topic Dodge AT4 D5N International AA AB vent window seals
Is it possible that the pivot point for the glass, at the top is in the wrong position?
Time to create page: 0.451 seconds
