- Thank you received: 1764
Mobile 1's Inter D1510 354
2 years 10 months ago #223560
Replied by Morris on topic Bonnet Hinge - d1510 inter
Another trick for new players with Inters and I suppose Dodges that have the same sheetmetal, is that as you close the bonnet YOU MUST hold the bonnet latch to the right as you push the bonnet home, or you WILL damage the bonnet or hinges.
The following user(s) said Thank You: Mobile 1
2 years 10 months ago - 2 years 10 months ago #223565
Replied by JOHN.K. on topic Bonnet Hinge - d1510 inter
If the hinges make the bonnet out of line as it closes,it must be pushed down at the back to line up properly............unfortunately,about the worst thing can happen in an Inter is trying to see through sheet metal at 60mph.............IMHO,two front side catches are absolutely essential,and just about every ex government truck had them fitted.......and if the bonnet tends to ride up at the rear,then fit two more spring side catches there as well........there is no overkill when the bonnet flies up as you are driving.
Last edit: 2 years 10 months ago by JOHN.K..
2 years 10 months ago #223570
by Mobile 1
Replied by Mobile 1 on topic Bonnet Hinge - d1510 inter
Thanks John K, Mobile 1 is a 2000 litre tanker still operational as private support to CFA and turn outs are often at a pace so will take onboard your advise, Regards John.
2 years 9 months ago #223740
by Mobile 1
Replied by Mobile 1 on topic D1510 Radiator Grille
Hi All, Can anyone advise the material the grille is made of also the best adhesive that will adhere to it as I need to repair it on the D1510 tipper I just purchased as I started today on her restoration.
- Thank you received: 4818
2 years 9 months ago #223751
Replied by Mrsmackpaul on topic D1510 Radiator Grille
AB were fiberglass, pretty sure that C and D are aluminium
2 years 9 months ago #223754
Replied by cobbadog on topic D1510 Radiator Grille
Hopefully yours is the fibre glass one. Buy a fibre glass repair kit that has both resin, hardener and matting. Follow the instructions acurately. Preparation is key to a solid repair.
2 years 9 months ago #223758
Replied by hayseed on topic D1510 Radiator Grille
I've got a D1910 Prime Mover, & It's some type of Plastic composite stuff ....
2 years 9 months ago #223763
by Mobile 1
Thanks Paul, If you have a look at the photo on my ID that is the grille ,it's some sort of plastic that I don't recognize, John.
2 years 9 months ago #223764
by Mobile 1
Thank You Cobbadog, Mine some to be some sort of plastic, John.
2 years 9 months ago #223765
by Mobile 1
Thanks Hayseed, Your are right ,it's strange sort of material , If you look at Mobile 1 photo on my ID that's the one, On my 1510 a couple of bars are broken and missing so I want to try and repair it and even pick up a broken grille to use as bits but unsure what will adhere to it. John.
Time to create page: 0.471 seconds
