- Thank you received: 1774
Bedford restoration with Chassis extension.
2 years 9 months ago #224171
Replied by JOHN.K. on topic Bedford restoration with Chassis extension.
rear mounted cranes put a lot of stress on the overhang ,and a Bedford with a tapered rail would need considerable reinforcement......Even bogie drives with heavy section all the way need something like 3 layers of reinforcement.......On a single drive ,behind the cab is where I would want a crane.
2 years 9 months ago #224172
by Bitsa
Replied by Bitsa on topic Bedford restoration with Chassis extension.
G'day John K
The Hiab is mounted, (or will be), Directly behind cab, I've only extended rear of Chassis to help support the tray
- Thank you received: 4807
2 years 9 months ago #224175
Replied by Mrsmackpaul on topic Bedford restoration with Chassis extension.
More photos the better, good to share the journey with us free loaders
- Thank you received: 547
2 years 9 months ago #224179
Replied by Blackduck59 on topic Bedford restoration with Chassis extension.
About the time Noah was transporting animals I worked for International.
We did a fair bit of chassis alterations, always straight cuts BUT we had a weld procedure/pattern to run something like 5 welds per side.
This was to prevent distortion of the rails but also slowed the heat input into the rails.
Acco's were easy, just tack on the end, D Lines you had to let a section into the middle so double welds.
Cannot see a problem with the angle cut.
2 years 9 months ago - 2 years 9 months ago #224199
by Bitsa
Last edit: 2 years 9 months ago by IHScout.
2 years 9 months ago - 2 years 9 months ago #224200
by Bitsa
Last edit: 2 years 9 months ago by IHScout. Reason: Hit insert after uploading the photos so that they appear with the text
2 years 9 months ago #224205
Thats a flash looking PTO and pump, all nice and shiny
2 years 9 months ago #224230
Replied by Swishy on topic Bedford restoration with Chassis extension.
Bitza
FWIW
Hope U followd the instructions fitn the PTO to side of cog box to get the correct gear backlash
also
to engage the PTO with engine run n with out grinding the gears
put the cog box into 1st (this stops the gears from turning}
engage PTO ........ then select neutral in cog box
FWIW
also
2 years 9 months ago #224238
by PaulFH
Replied by PaulFH on topic Bedford restoration with Chassis extension.
Guess there will be a few holes and bolts in the new section
for cross members and other fittings. Won't look out of place.
Neat job. Paul.
Neat job. Paul.
Time to create page: 0.616 seconds
