IH Gearbox Indentification
2 years 2 months ago #232745
by Browny59
IH Gearbox Indentification was created by Browny59
- Thank you received: 313
2 years 2 months ago #232746
by Inter-Action
Replied by Inter-Action on topic IH Gearbox Indentification
Perhaps a better photo showing gear stick location and number of bolts holding top on the box. I take it that it's the common 4 speed. Gear shift pattern
should be on the bottom corner of w/screen , drivers side. Dave.
2 years 2 months ago #232748
by Inter-Action
Forgot to mention. The plate attached to the passengers door should give you the g/box and diff model.
2 years 2 months ago #232750
by Browny59
Replied by Browny59 on topic IH Gearbox Indentification
Cheers Dave thanks for your reply.
I will add a couple of other pictures of the gearbox.
It's not the box out of the truck but an extra that came with the purchase of the truck
Tony.
Tony.
2 years 2 months ago #232759
Replied by asw120 on topic IH Gearbox Indentification
At this point, if it's a 4 speed I'm going to say it's a T98 / T15. Predecessor to the NP435 which would normally be in your C1300.
I have one in my ASW120. Don't know if they ever came in C-lines, but certainly the previous model.
The following user(s) said Thank You: Browny59
2 years 2 months ago - 2 years 2 months ago #232761
Replied by JOHN.K. on topic IH Gearbox Indentification
Early C lines had the T98A,later C lines and Dlines had the T17...NP...obvious difference is the cast iron vs alloy top.............By the way ,both boxes have two versions which are not directly interchangeable 6cyl petrol ..vs ..V8petrol/Perkins.
Last edit: 2 years 2 months ago by JOHN.K..
2 years 2 months ago #232784
by Browny59
2 years 2 months ago #232786
by Browny59
Ten spline shaft.
6 bolts holding the top cover on.
2 years 2 months ago - 2 years 2 months ago #232812
The large (1") front bearing clutch shaft is for the two piece housing and six/ V8 petrol /Perkins............but not for the one piece housing on 1100./1200/1300
Time to create page: 0.498 seconds
