What Inhibitor For A 903
10 years 1 month ago #140008
by D40Inter
What Inhibitor For A 903 was created by D40Inter
Can anyone tell me what inhibitor I should run in a 903 also should I run any particular coolant.
10 years 1 month ago #140009
by paulc20
Replied by paulc20 on topic Re: What Inhibitor For A 903
I'm still running Fleet Guard Compleat 50 in mine, unfortunately it is no longer available. After my last filter change and a hose replacement I topped it up with Gulf Western All Fleet Heavy Duty Diesel Concentrate. They claim this is compatible, and is designed for heavy duty wet sleeve diesels and the sca additive. I have been using the pre charged (3 unit I think) with sca fleet guard filters, but haven't been able to check the concentration in the system properly as the local supplier always seems to have out of date test strips.
www.gulfwestern.com.au/Data%20Sheet%20do...20Coolant-2-2014.pdf
10 years 1 month ago - 10 years 1 month ago #140010
by busntruck
Replied by busntruck on topic Re: What Inhibitor For A 903
I used to use Fleetgaurd DCA4 and got it from local Cummins dealer.
Last edit: 10 years 1 month ago by busntruck.
10 years 1 month ago #140011
Replied by hayseed on topic Re: What Inhibitor For A 903
I just buy 200 litre Drums of Premixed Stuff off Cummins (Fleetguard).And run it in everything from the Lawn mower Up..
I still refer to It as TEC50.
But It's now called something else (not too sure what)
10 years 1 month ago #140012
by paul404
Replied by paul404 on topic Re: What Inhibitor For A 903
Go to your local KW dealer and use their All Rig pre-mixed coolant. Spin on a zero unit water filter. Top ups are done with the pre-mix. Keeps it simple.
10 years 1 month ago #140013
by dieseldog
Replied by dieseldog on topic Re: What Inhibitor For A 903
It shouldn't matter too much mate, just make sure its a good quality one. It does pay to shop around, there are some that are good for half a million clicks and all that's required is a filter change every year to keep up the DCA.
10 years 1 month ago #140014
by newto
just put a fleet guard wf2075 water filter and a bottle of fleet guard DCA65L and she'll be fine!
903's were around long before all the pre mixed coolant became necessary
Replied by newto on topic Re: What Inhibitor For A 903
10 years 1 month ago #140015
by dieseldog
Just bear in mind that one will have no anti freeze/anti boil protection with water.
Considering the negligible cost of coolant over tens of thousands or even half a million kilometres, I'd run a modern coolant and reap all the benefits...
10 years 1 month ago #140016
by newto
if "one" needs anti boil protection "one" should be checking thermostats,water pumps,bleed lines and radiators!!
pre 1988 engines were designed to run on water with DCA additive.
the latest "modern" coolant from fleetguard that is supposed to be so environmentally friendly that us humans could probably drink it is causing lots of water leaks from pre 1988 gaskets and seals that weren't designed to handle the latest chemicals
10 years 1 month ago #140017
Replied by on topic Re: What Inhibitor For A 903
...jeeeez newto .. and i thought i was becoming a bit of a hard arse!
Time to create page: 0.405 seconds
