Vacuum actuating valve on early Commer
- Hommie1973
5 years 9 months ago #194871
by Hommie1973
Vacuum actuating valve on early Commer was created by Hommie1973
Hi, Can anybody tell me how the valve works to allow engine Vacuum to enter the Booster? The truck is a 1951 Commer QX R7 with the Clayton Delwandre systerm. It is a double valve and I can see how it helps apply the brakes but I cannot see how the engine end of the valve comes off its seat to connect the engine Vacuum. Obviously it comes off its seat some how to allow the Vacuum in, but I am at present thinking the valve is not held forward but centred when the brakes are not being used. Any help on this would be much appreciated, I do have a maintainance manual but it is confusing as to how this works. Cheers Hommie
5 years 9 months ago - 5 years 9 months ago #194872
Replied by asw120 on topic Vacuum actuating valve on early Commer
Might it work something like a PBR where the vacuum is controlled by the small piston under pedal (hydraulic) pressure?
(input side, before the output piston)
I had to have one in bits and the book there to work that one out.
Last edit: 5 years 9 months ago by asw120.
The following user(s) said Thank You: Hommie1973
- Hommie1973
5 years 9 months ago #194880
by Hommie1973
Replied by Hommie1973 on topic Vacuum actuating valve on early Commer
Hi Jarrod, Good news I've managed to work it out last night after a long look at the lever mechanism fulcrum set up in the front of the housing. It certainly is an amassing set up the way it works, it pulls and then pushes the vacuum valve to introduce the Vacuum and then opens the atmospheric valve to release. Thanks for getting back to me on my problem. All good now Cheers Hommie
5 years 9 months ago #194881
Replied by Swishy on topic Vacuum actuating valve on early Commer
Guess n the reason U aint gunna find much info on the workings
is cos of saftey....... they probly dun wanna see people playing with the gizzmo
and prefer U buy a new one ..... coz if it fails ......... U'll B 1st to kno bout it
Time to create page: 0.448 seconds
