Rolling an edge on curved steel
2 years 11 months ago #222546
Replied by Lang on topic Rolling an edge on curved steel
Dave
Try this one.
Try this one.
2 years 11 months ago #222547
Replied by jon_d on topic Rolling an edge on curved steel
I would go the way of making the section separate of the guard. Profile it and curve it on the bench.
Then you can walk up to the guard and rest it against it to see the shape and fit.
When right, trim the guard and notch it. And then weld in the section already made and bog the line. (or even lead sweat if they still do that.)
Something like this does the little fold/notch to make a flush joint.
www.tradetools.com/renegade-industrial-a...flange-tool-rizk9201
2 years 11 months ago #222548
Replied by Dave_64 on topic Rolling an edge on curved steel
Blokes make it look easy when you have a pinch roller at your disposal, bit hard trying to feed a complete cabin through one though, when the guards have already been welded on (previous owner!). Still, a few ideas on how to insert a beading, like Mrs. said.
I have one of those air operated punch affairs, alright on flat larger areas, try doing it on a small diameter hole , not so good. Great for putting a step in for say doing outer door skins etc. Thanks, Dave_64
2 years 10 months ago #222565
by mikeg
Replied by mikeg on topic Rolling an edge on curved steel
Watch the vid that Lang put up that's the proper way. Wiring an edge is not as difficult as you might think, all that is need is patience and a little bit at a time, a couple of decent dollys, a planishing hammer and some vice grips to hold the wire in place.
2 years 10 months ago #222573
Replied by cobbadog on topic Rolling an edge on curved steel
Dade showed me year ago how to do a wired edge but he had a swaging machine to turn an edge to start with then finish with hammer and dolly with the wire.
Over the years I have watched Ian Rowsell on Full Custom Workshop and he has often simply welded a solid rod to the raw edge of the guard. Depending on the look you want anything from 1/4" - 3/8" looks great and is easy to shape by hand as you, or your mate, tacks it in place. Then a few runs and finish off with filler.
Time to create page: 0.441 seconds
