- Thank you received: 929
Maxitorque transmission input numbers
1 year 9 months ago #237692
Replied by Dave_64 on topic Maxitorque transmission input numbers
I stand corrected re the input shaft diameters on the Maxitorque box.
Had to pull one out of a Flintstone 237 when working on the spanners all those years ago, kept jumping out of the lower gears.
Maynes ran the 5 speed directs on linehaul in both 237 and 285 guise, gteat box once you got used to them.
Maybe the 375 ran a larger clutch plate than the smaller 6's, I feel there was sometimg different between them??
The one we reefed out of the Flintsone I do recall had to be timed, something that we hadnt come across before.
Ended up getting a service exchange from Gleemans, gave her a coat of paint and probably still going.
Dave_64
Dave_64
1 year 9 months ago #237724
by Kav
Replied by Kav on topic Maxitorque transmission input numbers
Back in the days of the early V8's and the Flintstones the clutches were originally push type. In 1979, I had a 6 cylinder Maxidyne that Mack told me, had a V8 clutch fitted, which was a heavy push clutch, with a different Flywheel and centre plate. Mack changed the flywheel and centre plate to the later 6 cylinder one as they said that some parts were not available for the old V8 clutches. The Pull-type Spicer clutches were then available, so that was the way to go.
The following user(s) said Thank You: Dave_64, Mrsmackpaul
Time to create page: 0.340 seconds
