- Thank you received: 46
Oil Filters
- Tired Iron
3 months 4 days ago #250390
by Tired Iron
Oil Filters was created by Tired Iron
More for the brains trust.
Oil & filter change time.
I just watched a bloke fill his CAT oil filter with new oil before he screwed it back on.
Then he proceeded to put the rest of the oil charge in via the filler.
I have never "pre-filled" any oil filter before.
Just wacked it in, whatever the charge is meant to be, check on the dipstick before starting and again a few minutes after running
Is his method better/worse, right/wrong?
Enquiring minds etc.
Thanks in advance
Thanks in advance
- Thank you received: 280
3 months 4 days ago #250394
by 77louie400
Replied by 77louie400 on topic Oil Filters
Always prefill
3 months 4 days ago #250396
by V8Ian
Replied by V8Ian on topic Oil Filters
I always pre fill filters, as it saves that amount of oil that the filter has to prime, meaning less/minimal time the engine is running without pressurised lubrication.Â
- Thank you received: 600
3 months 4 days ago #250403
Replied by 180wannabe on topic Oil Filters
I always pre-fill where possible.
3 months 4 days ago #250404
Replied by Morris on topic Oil Filters
I was told that if you do not pre-fill, the bearings etc. are running without oil until the oil pump fills all the galleries.
- Thank you received: 546
3 months 4 days ago #250409
Replied by Blackduck59 on topic Oil Filters
Funny Cat used to specify DO NOT fill the filters in their engine manuals.
Personally the oil in the system is enough for a start and idle with less chance of junk going into the engine.
3 months 3 days ago #250413
Replied by cobbadog on topic Oil Filters
Blackduck that would be because Cat sell you new engine kits more often
3 months 2 days ago #250439
Well think of older units with horizontal filter housings and elements, not spin-ons. No chance of filling those and they survived quite well.
