- Thank you received: 46
Holes Drilled in Chassis
- Tired Iron
1 week 3 days ago #251630
by Tired Iron
Holes Drilled in Chassis was created by Tired Iron
Hello All
I’m in Asia and saw a big lump of a late model Benz tipper, with camel back suspension on the road.
Every visible bit of chassis had neat & had to be factory drilled holes in the vertical section.
I’ve seen this before in small areas, but never the entire length.
Now I always thought the more holes you had the more you weakened the beam.
Maybe that only applies to the horizontal section?
Enquiring minds etc
Thanks in advance
Enquiring minds etc
Thanks in advance
1 week 2 days ago #251636
Replied by mammoth on topic Holes Drilled in Chassis
Depends where the holes are and size. A lot of Japper chassis are full of holes, presumably for every variation of model/options.
1 week 2 days ago #251637
by Bluey60
Replied by Bluey60 on topic Holes Drilled in Chassis
I was always told to drill a hole at the end of a crack to stop it going any further perhaps their getting a head start
Bluey
Bluey
1 week 19 hours ago - 1 week 19 hours ago #251646
Replied by jon_d on topic Holes Drilled in Chassis
yep, otherwise it would go all the way around to your belly button.
Last edit: 1 week 19 hours ago by jon_d.
- Tired Iron
6 days 11 hours ago #251653
by Tired Iron
Replied by Tired Iron on topic Holes Drilled in Chassis
Yes Mammoth has to be right.
Definitely factory job from new.
Approx 1/2" holes, all the way along.
Just never seen that before, and must not effect beam strength
Tks
Tks
The following user(s) said Thank You: wee-allis
5 days 1 hour ago #251663
Replied by Lang on topic Holes Drilled in Chassis
When I got the Bean it had the chassis drilled with 3 inch holes all the way along just as Birtles had.
I asked a structural engineer to look at it. He said the holes in most places actually strengthened it (vertical web only). points of stress such as spring mounts and cross braces should not be drilled. He said the holes gave a triangulation effect and alsomentioned a 100 ton crane boom is 90% air
Aircraft ribs and load bearing structures all have large holes punched in the webs.
I don't know but sounds good tome
- Thank you received: 20
4 days 18 hours ago #251667
by grumpy gumpy
Replied by grumpy gumpy on topic Holes Drilled in Chassis
A lot of "hot rodders " will put "dimples" in panels and chassis rails to add strength and to lighten the panel/rail . These holes have a raised inside edge that compresses the steel to add strength and rigidity
Gumpy
Gumpy
Time to create page: 0.484 seconds
