Re: Chassis number locations -put them in here
12 years 3 months ago #72464
by tonym
If you can't afford a Dodge
Replied by tonym on topic Re: Chassis number locations -put them in here
Includes 1970 IH C1600, 1300....AR series International Left front chassis rail
12 years 3 months ago - 12 years 3 months ago #72465
Replied by on topic Re: Chassis number locations -put them in here
... have an S model with a bumper bar from 1964 (ex ansett) and the ch/no is stamped on the upper rh flange near the bonnet hinge pivot
you'll have to go a long way to find an original bumper off any of these old KW's around that age...let alone the chassis number on it!!
cheers
cheers
10 years 1 month ago - 10 years 1 month ago #72466
....to help werkhorse, and also anyone else wanting to get to the bottom of their endeavours to find their ch/no's, this thread is still pretty handy....cheers fellas....
10 years 1 month ago - 10 years 1 month ago #72467
Replied by Sarge on topic Re: Chassis number locations -put them in here
Some of you blokes are gunna need to jab me with a burnt stick.... as I happen to have access (at work) to the gospel... 1970 edition
try me.
/me
try me.
/me
Last edit: 10 years 1 month ago by Sarge.
4 years 1 week ago - 3 years 11 months ago #209403
by Jobbo
Replied by Jobbo on topic Re: Chassis number locations -put them in here
G'day all, I realise this is an old thread but perhaps it still gets a bit of interest!
If VIN's didn't come in until early 1980's is the chassis number regarded as the Vehicle Identification Number?
And if so, is that all I'd expect to find on an International D1950 Prime Mover or are there other 'factory' plates for ID and if so where are they likely to be?
Truck is approx 1971 vintage Cummins C-175 engine, Spicer? box - anybody, please? Michael
Last edit: 3 years 11 months ago by hayseed. Reason: added pic
- Thank you received: 601
4 years 1 week ago #209408
Replied by 180wannabe on topic Re: Chassis number locations -put them in here
Hi Jobbo.
Yes, you would use the chassis number. It should be found stamped at the front of the LHS chassis rail, on the outer face, near the front spring hanger.
Check the latch end of the passenger door for factory ID plate.
The following user(s) said Thank You: Jobbo
3 years 11 months ago #210144
Replied by PDU on topic Re: Chassis number locations -put them in here
K,M, O Bedfords RH chassis rail, top face, just behind steering box and attached with two split pins!? Easy to move/change/swap??? :blink:
3 years 6 months ago - 3 years 6 months ago #215882
by WorkTruck
Replied by WorkTruck on topic Re: Chassis number locations -put them in here
K Series - Chassis number stamped on very Front Left Chassis Rail (ie. US Driver Side)
mine is a K2-R 12287 (Manuf date ~1942)
I have a PDF of the IHC-USA Truck Serial number list 1928-1966, I tried to post here but doesnt allow pdfs...
(Note to self saved in K2-R File)
Last edit: 3 years 6 months ago by WorkTruck.
- Thank you received: 1174
3 years 6 months ago #215885
by Southbound
Replied by Southbound on topic Re: Chassis number locations -put them in here
International C1 1934 & 1935
Left hand chassis rail, vertical face, at the front between the bumper and the shocker.
3 years 6 months ago #215899
by Brocky45
Replied by Brocky45 on topic Chassis number locations -put them in here
I did not go back and reread this whole topic so may be repeating. Up here in the States, Diamond T is on the right frame rail above the rear steering axle spring hanger. The data plate before 1950 is on the right side of the cowl and after 1950 on the right door frame. These sides may be reversed for you Down Under with RHD??
Time to create page: 0.540 seconds
