- Thank you received: 1114
Unknown overdrive gearbox car / light truck.
8 months 1 week ago #247884
Unknown overdrive gearbox car / light truck. was created by asw120
Hi all, I have been meaning to post this for some time. It's a 3 speed with overdrive, as near as I can tell. It came with a load of Studebaker parts, which had a smattering of other stuff thrown in. There are no remains of markings on the tags. Any ideas?
Thanks, Jarrod.
Thanks, Jarrod.
- Thank you received: 4807
8 months 1 week ago #247887
Replied by Mrsmackpaul on topic Unknown overdrive gearbox car / light truck.
So is thay
first low
Second direct
Third overdrive ???
first low
Second direct
Third overdrive ???
8 months 6 days ago #247907
It has just occurred to me that there is no solenoid like usual on this one.
Replied by asw120 on topic Unknown overdrive gearbox car / light truck.
Standard 3 speed with an overdrive unit on the back, like old Studes and Chrysler Royals and early Toyota Crowns and some pommy stuff.So is thay
first low
Second direct
Third overdrive ???
8 months 6 days ago #247909
Replied by cobbadog on topic Unknown overdrive gearbox car / light truck.
No solenoid but looks like a selector lever at the rear on the o/d section so maybe a seperate rod to another lever?
8 months 6 days ago #247910
Replied by JOHN.K. on topic Unknown overdrive gearbox car / light truck.
Probably had a vacuum chamber working the lever ......pull a bolt and see if its metric ......looks Japanese to me.
8 months 6 days ago - 8 months 6 days ago #247911
Replied by Dave_64 on topic Unknown overdrive gearbox car / light truck.
Not one of those Laycock de Normavilles that the poms used to like on their Armstrong Siddleys, Austin Healy's even some of their Humbers??
Had one years ago looked a bit similar, had electric solenoid and planetary drive with fifty thousand springs!
Mate had similar thing in a Healy but had a vacuum solenoid??
Although having another look at the shape of the box itself as well as the shifter housing, it does resemble a Warner or NP tranny?
Damn interesting though!
Dave
Dave
Last edit: 8 months 6 days ago by Dave_64.
8 months 5 days ago #247914
There's a lot of bolt holes in the bell housing
And it looks like the clutch is more like a truck type than a car type, yet the transmission itself looks tiny
And the clutch looks like it is operated from the left so would this be a LHD vehicle?
8 months 5 days ago #247917
Lang, just threw it in there as a 'maybe', but happy to be corrected!
As I said, tranny ribbing and size puts me in mind of either a Warner Gear or an NP.
If it came with a few Studey bits and pieces, fair chance it is one of their overdrive units, Believe Studey used both them and a version of the Warner T10 in their 289 V.8's.
The cable has me thrown a bit though, possibly something to do with either the speedo drive or the remote to pull it into overdrive via some sort of solenoid or vacuum control??
Dave
Dave
8 months 5 days ago #247918
Replied by Lang on topic Unknown overdrive gearbox car / light truck.
If it is overdrive the speedo connection will have to be shifted to the back of the overdrive unit or it will read wrong in the normal gearbox direct drive output position.
Is it one of those "free-wheel" units that gained popularity in the late 30's on fancy cars such as Chryslers?
Time to create page: 0.556 seconds
