- Thank you received: 1695
sleeper cab 1917-1950
I hope this piece of ingenuity has survived.
Thanks for posting these photos.
Ray.
- Dima Ukraine
- Thank you received: 4202
- Dima Ukraine
- Thank you received: 12
1964 Bedford bus/motorhome
1972 Bedford bus/motorhome
...and sundry other 2, 3 and 4 wheel vehicles...
Dima Ukraine wrote:
Can you specify the arrow where the sleeper was?Kwakatriple wrote:
These are a couple of pics of my Dad's AEC taken 6 years ago (I believe it is now restored). He built this truck in the late 50's and it has the sleeper in front of the driver. .
Hi Dima Ukraine, sorry I did this wrong to start with so this, along with a pic, appears in a different post below.
If you look at the windows in the cab you will see there are three windows at the side. The front, slightly angled, corner window, a fixed pane window and then the door window (which is open in the pic). The angled window and the fixed pane window are at the end of the sleeper section which is right across the front. The base of the bed was probably about in line with the top of the radiator grill so that with blankets etc it was just below the bottom of the windscreen. The driver (and passenger) seats are in line with the door and the steering wheel actual circled slightly over the back edge of the bed. I have attached a crude sketch of the layout of the cabin - see below.
- Dima Ukraine
Thank you very much my friend! What is the width of the bed? If possible, provide more photos.Kwakatriple wrote: Hi Dima Ukraine, if you look at the windows in the cab you will see there are three windows at the side. The front, slightly angled, corner window, a fixed pane window and then the door window (which is open in the pic). The angled window and the fixed pane window are at the end of the sleeper section which is right across the front. The base of the bed was probably about in line with the top of the radiator grill so that with blankets etc it was just below the bottom of the windscreen. The driver (and passenger) seats are in line with the door and the steering wheel actual circled slightly over the back edge of the bed. I have attached a crude sketch of the layout of the cabin.
I am sorry but I do not have any other photos at the moment. I know there were some in existence but my father passed away some years ago and I have not yet found the photos.
From memory the bed was about single bed width - perhaps 3 feet wide. I seem to recollect that Dad got a foam mattress specially made for it and that makes me think it was not a standard single bed width.
- Dima Ukraine
Maybe later you can find more photos ...
- Dima Ukraine
- Dima Ukraine
