Mystery panel vans
8 years 4 months ago #165663
by Mairjimmy
Replied by Mairjimmy on topic Mystery panel vans
Here is a panel van but I wouldn't think it a mystery one,
I would think they would have been built around 1954 or 5 as we had one of the one on left in late 1955
The one behind the FE, the photo was taken when the FE was traded on a FB 1960
Colin
Colin
- Roderick Smith
- Thank you received: 307
8 years 4 months ago #165665
by Roderick Smith
Replied by Roderick Smith on topic Morris van & utes
Wow: four great vehicles in one photo.
The two Morris Minor utes have the raised headlamps and mesh grille: 1952-56.
I haven't worked on the Oxford, which had a larger motor.
The van at the rear came as both Morris and Austin; we had a thread a few years ago.
Roderick
Roderick
8 years 4 months ago #165676
Replied by Morris on topic Morris van & utes
The Morris Oxford ute (on the left, at the front) is a Series 2 circa 1952-54. The Morris Minor panel van and ute are 1952 to 1954 as they have the split windscreen and narrow grille. I used to know all the Morris Minor yearly changes when my parents had a 1952 and my Sister a 1955 but I got old! (I had a 1959 Austin A55 In the Farina of Italy body (same as Morris Oxford Mark 6 and Austin Freeway)
The squarish van behind is a Morris LD (Light Delivery?) They went through LD1 to LD5 over the years but are usually all known as LD5's. I have one for sale.
The truck behind it appears to be a Morris Commercial LC3 (Light Commercial?) from 1939 and then after the War from 1952 to 1956 and may be the LC3U, which had a large well-side ute body virtually identical to the Dodge utes.
Morris.
Morris.
The following user(s) said Thank You: Roderick Smith
8 years 4 months ago #165699
Whoops!
I should have written the LC3 was made in 1939 (before the war) and again after the war from 1946 to either 1952 or 1956, depending on which history you read. Sorry about that Chief! as I said, I am getting old.
Interestingly, it's replacement, the LC5 was made from 1952 onwards. There was also a short-lived interim LC4 with the LC5 (Austin A70) motor in an otherwise all LC3 body/chassis.
Morris.
Morris.
- Roderick Smith
8 years 4 months ago #165703
by Roderick Smith
Replied by Roderick Smith on topic Morrises
I am boning up on Morris Minors, as I have a friend who has just obtained a barn-find 1958 Australian built Minor. In just 4 weeks he has cleaned it, had the motor running, and now has the roadworthy, ready for club plates. It isn't commercial, and isn't even a ute/or van.
Roderick
Roderick
8 years 4 months ago - 8 years 4 months ago #165816
by VicHung
Hi Morris, I too have got old but isn't that Morris Oxford the original post-war side-valve Oxford called the MO series but retrospectively called the Series 1?
I seem to remember that the Series 2 was a completely different model with a larger body and an OHV engine but as always IDSTBC!
Vic
Replied by VicHung on topic Morris van & utes
Morris wrote: The Morris Oxford ute (on the left, at the front) is a Series 2 circa 1952-54. Morris.
Vic
Last edit: 8 years 4 months ago by VicHung. Reason: Typo
8 years 4 months ago #165823
VicHung,
On second thoughts, I agree you are correct. The first few months of MO production had drooping front corners on the bonnet. These were thought to be dangerous to anybody working around the front of the vehicle when the bonnet was raised, so the front edge of the bonnet was straightened out and small filler pieces fitted to the body of the vehicle to fill the spaces.
I would like to find an MO or Series 2 Ute or Panelvan.
Morris.
Morris.
8 years 4 months ago #165850
by Mairjimmy
Well the Morris Panel vans caused a bit of interest, what about theses
The only one I could have a guest at is the one on the left, Austin A30 or A40
Colin
Colin
8 years 4 months ago #165851
by VicHung
Replied by VicHung on topic Mystery panel vans
L to R.........
Austin A40
Ford E83W
Ford E83W
Ford E83W
Bedford CA
Austin A40
Ford E83W
Ford E83W
Ford E83W
Bedford CA
8 years 2 months ago #168356
by Zuffen
Replied by Zuffen on topic Mystery panel vans
Time to create page: 0.480 seconds
