- Thank you received: 1740
1968 Atkinson 8 wheeler for L.Arthur & Co
6 years 1 month ago #192476
Replied by JOHN.K. on topic 1968 Atkinson 8 wheeler for L.Arthur & Co
The 1676 motor was double OHC,and the cams of each head had a train of gears up the block,one at the front ,one at the back....17 gears in all.The heads had screw in precombustion chambers.As mentioned ,only fitted to one machine ,the 621J scraper.They were very prone to crankshaft failure,and cracked heads....I reckon Atkinson got them cheap,which is why they used them....
6 years 1 month ago #192485
Replied by Dave_64 on topic 1968 Atkinson 8 wheeler for L.Arthur & Co
Some time ago, asked the question about Atkinsons with Kirkstall "Omega" diffs.
I also recall Swishy posting a photo and a bit about Mecho Plant Hire's float.
I could have this wrong, but they were rated at something like 90,000lbs.
Wonder if this 8 wheeler has the same back end ??
Seems like an eon ago, and I am probably wrong again, but I have either seem, or read somewhere, of a set-up that had a combination of double reduction worm drive diffs as well as the planetary hub reduction.
Dave
Dave
6 years 1 month ago #192501
This truck has Omega diffs.The centres are double reduction,like a Mack.The hubs look very like Leyland H /WT ones.
- Foden Delta
- Thank you received: 7
6 years 2 weeks ago - 6 years 2 weeks ago #192815
by Foden Delta
Replied by Foden Delta on topic 1968 Atkinson 8 wheeler for L.Arthur & Co
Jeffo wrote "She must have short prop shafts ?"
Yes, the front shaft between the gearbox and auxiliary is 14"
The second propshaft is 35"
Last edit: 6 years 2 weeks ago by Foden Delta.
- Foden Delta
6 years 2 weeks ago #192816
by Foden Delta
- Foden Delta
6 years 2 weeks ago #192817
by Foden Delta
- Foden Delta
6 years 2 weeks ago #192818
by Foden Delta
John, the diffs don't have a double reduction in the centre, just a normal hypoid centre but upside down due to axle rotation and the hub gearing arrangement.
I have a manual for the diffs so I will add some sectioned details here soon for your viewing.
JOHN.K. wrote: This truck has Omega diffs.The centres are double reduction,like a Mack.The hubs look very like Leyland H /WT ones.
6 years 1 week ago #192953
Replied by bigcam on topic 1968 Atkinson 8 wheeler for L.Arthur & Co
Nice truck Foden Delta, I'm guessing it would sound pretty good.
40 years with the same engine in it is not bad, is it low K's?
Only reason I ask is a lot of heavy haulage trucks are geared down and specced up that they are not much good for anything else.
That Bullbar would be pretty easy replicated.
Dave 64, 3406 and 3408 are from memory late 70's, the 3406A was 70's, pre combustion and use more fuel than a GM.
6 years 1 week ago #192958
The Cats could use brown diesel,which was cheaper,especially if you had a dozer or a farm,and could crib on the road tax.Caterpillar always made a big deal of using cheap fuel.The 3406/8/12 were very good motors,,later changed over to direct injection...Seen claimed good runners on ebay for $500.....big tho,weigh 1 1/4 ton for the 6.
Time to create page: 0.448 seconds
