- Thank you received: 1695
Grey Ghosts air cleaner set up
3 years 1 month ago #220176
Replied by Swishy on topic Grey Ghosts air cleaner set up
Guess n
the air cleaner would B like a mack one
with all the dirt collecting on the inside of element
Butt
there again
wadda eye kno
SFA by the sound of it
Butt
there again
wadda eye kno
3 years 1 month ago #220197
by IHScout
Dennis
Replied by IHScout on topic Grey Ghosts air cleaner set up
There would be a greater surface area to the outside face of the element, so it would make better sense to have the air flowing through from outer surface to inner surface so the accumulating dust doesn’t restrict the flow as quickly.
Dennis
3 years 1 month ago #220236
by Bobsboy
Mucking about on the edge
Replied by Bobsboy on topic Grey Ghosts air cleaner set up
Overnight rain?
3 years 1 month ago #220253
by overnite
Replied by overnite on topic Grey Ghosts air cleaner set up
Too fast for the rain to get in.
- Thank you received: 4808
3 years 1 month ago #220261
I beg to differ
The element is the same size inside or out as the sheet of paper has two sides that makes the element up so it has to be the same size each side
I think it would be more efficient to enter the element directly as is common on older Macks
If it would make any noticeable difference ? I doubt it
All the bends in the intake would do more to restrict it than the air cleaner
Replied by Mrsmackpaul on topic Grey Ghosts air cleaner set up
IHScout wrote: There would be a greater surface area to the outside face of the element, so it would make better sense to have the air flowing through from outer surface to inner surface so the accumulating dust doesn’t restrict the flow as quickly.
I beg to differ
3 years 1 month ago #220264
by werkhorse
Replied by werkhorse on topic Grey Ghosts air cleaner set up
There were several diff versions used by TNT on the Ghosts... Depending on what year/batch... If you look at enough Ghost photos you'll see the different set ups
3 years 1 month ago - 3 years 1 month ago #220266
Replied by cobbadog on topic Grey Ghosts air cleaner set up
I can see what Paul is saying about the same amount of paper in the element b ut the difference that I se is the volume of air around the element. To my odd way of thinking there would be a larger volume of air aroun d the outside of the element than in the centre and this could be where a difference could occur.
Last edit: 3 years 1 month ago by cobbadog.
- Thank you received: 839
3 years 1 month ago #220267
by BillyP
I used to be a truck driver,
on a good day i can remember
Replied by BillyP on topic Grey Ghosts air cleaner set up
.Doesnt the air flow direction have something to do with the garbage being
caught in the bowl area.
...................Billy.................
3 years 1 month ago #220270
Replied by Lang on topic Grey Ghosts air cleaner set up
I think they are two different makes of air cleaner. The restored one is definitely correct plumbing (I have the same unit on both my OKA and Mack). There is a steel inner surround around the element that the incoming air hits causing it to swirl and dump dust into the can before entering the element' It also stops water directly hitting the element and sends it to the bottom of the can to drain out a duck-bill outlet.
The original looks like it gets its initial heavy particle separation from the intake cap . There must be some separation before the element or it would last 5 minutes in dusty conditions. Maybe someone can give info in the original?
Time to create page: 0.565 seconds
