- Thank you received: 547
Grey Ghosts air cleaner set up
The FW the air enters the side, goes over the fins then through the filter and out the top.
Guess the Cyclopac name refers to the cyclone action of the air passing those fins and hopefully dumping most of the dirt into the collector/base cover.
Blackduck59 wrote: roKWiz, sorry the only inside to outside one on that list is the EBA.
Nup, you lost me, I;m curious now.
Doesn't the air enter from the top on a FW, the most commonly use Cylcopac on cabovers ? Like shown
Anyone one know what EBA means, shop manuals give no reference to the initials.
Heritage Stonemason
Does not show in your pics but do those have the evacuator (duck bill) boots on the lower cover? If so they are plumbed wrong for dirt control. Will still work but life of filter maybe a little shorter.
Blackduck59 wrote: Got me too.
Yes, they are mounted towards the centre of the lower removal debris pan
Damn that Kenworth company for building my truck wrong.
Heritage Stonemason
Side entry, steel cover opposite intake, dust and water into can and out a bottom duck-bill outlet. No fins on filter element.
My Perkins OKA has exactly the same unit but about 2/3 the size. There are two paper filter element "tubes" one inside the other with no fins.
If the air goes into the centre of the filter as shown how does the debris pan and evacuator work? Maybe KW figured with the intake above the cab there was not enough excess dirt to worry about. The evacuator will still let any rain drain out.
Never liked the air filters that take the air from the outside of the element into the engine, any bad cover seal, cracked housing or rust holes and dirt has a direct entry into the engine.
Just my theory.
I note on the ones I been looking at have the duck lip in the centre of the bottom pan. Similar to SAR and W model Donaclones.
My Mazda and Ford Traders (all Perkins type diesels) earlier cab one has the fins cyclone effect air filter, later one don't but all use a similar air intake set up.
Heritage Stonemason
