- Thank you received: 4809
Acco/ Atkinson and inters…
2 years 5 months ago #229380
I guess the thinking is the trailer cant move on its springs when tipping
It would be a very unstable trailer to tip and I guess every bit helps
Replied by Mrsmackpaul on topic Acco/ Atkinson and inters…
I’d say if that was the aim, it wouldn’t provide much more stability. Be useless when you were trying to run the load out. Just my opinion.
2 years 5 months ago #229382
Couldn't agree more mate.. It's a Chassis Tip so all the Wheels stay on the Ground when Tipping.. Just My Opinion Too..
Replied by hayseed on topic Acco/ Atkinson and inters…
2 years 5 months ago - 2 years 5 months ago #229392
by overnite
Replied by overnite on topic Acco/ Atkinson and inters…
Paul, yes, very nerve wracking days for me with a 30’ TOA trailer when the customer wants the load run out in a new subdivision with a bit of camber on the road.
Last edit: 2 years 5 months ago by overnite.
- Thank you received: 839
2 years 5 months ago - 2 years 5 months ago #229394
by BillyP
I used to be a truck driver,
on a good day i can remember
Replied by BillyP on topic Acco/ Atkinson and inters…
Im with ole nitey.......
The whole thing doesnt make much sense to me ......unless for a specific operation...like
tipping into bins at a batching plant .........
Looks like it was designed by a university graduate............
..................Billy...................
Last edit: 2 years 5 months ago by BillyP.
2 years 5 months ago #229400
Replied by cobbadog on topic Acco/ Atkinson and inters…
That weird looking tipper body with the wide spread axles plus the extra legs mentioned then a divider in the tipper body, the body is shorter than the draw bar which wastes a heap of space and puts less weight over the drive axle. Was the designer drunk when he drew that one up?
The other interesting thing I noticed is with the rigid tipper and the pay loader behind it. Truck is RH drive, what is that in the passenger seat? Looks like an effigy if the thing from the AIDS advertising, only with out the scythe.
2 years 5 months ago #229407
Replied by Lang on topic Acco/ Atkinson and inters…
Maybe the legs were to provide support because when it was tipped the entire load would go on the back axle and cause mischief to the suspension. Much the same as some beavertails and machinery trailers have drop down support legs at the back for use while loading. A WAG.
2 years 5 months ago #229410
CORRECT LANG, as the Swishman says "you can have a beer from your very fridge
I thought I had said that earlier
The reason the trailer is the way it is ?
We had these weird bridge laws for loading so to load to the maximum the the
load had to be spread out over a long distance
And this was one of the many ways that were devised to over come the issue and stay fully with in the law
Kirky that used to be on here got very angry with me once about this photo because he couldn't quite cotton on to the reason why
The reason is simple for the legs, its like tipping a trailer with the load stuck up the front of the tipper and when the trailer reaches a certain height the load slides in hurry and makes the trailer very unstable and likely to to tip over
Winding the legs down means the trailer cant rock so stability is restored and it is safe again
Some people refuse to see this for some reason
Anyway I have tried to explain the reasons why to the best of my ability
2 years 5 months ago #229414
Replied by JOHN.K. on topic Acco/ Atkinson and inters…
The pic with the 966 loader...looks like the house owner is looking into the hole they're digging right under his side wall.
2 years 5 months ago #229418
Replied by Swishy on topic Acco/ Atkinson and inters…
1974 Atkinson made a few trucks for Readymix & Monier Sand one was never picked up either so we grabd it
8V-71 318 HP Jakes RTO 9513 Hendrickson
we stihl have it in the grave yard in the back of our shed under cover
the bridge laws of the day had the wide spread along the trailerto gain max loding
thinkn way back then the trailer might have been on air suspension BIDS2BC
the land n legs were OK dump n on a flat concrete apron @ there batch n plant
Time to create page: 0.638 seconds
