- Thank you received: 2501
8 stud tubeless rims to suit 1973 Denning
1 year 4 months ago #242094
Replied by hayseed on topic 8 stud tubeless rims to suit 1973 Denning
Maybe, Get a Machine shop to weld Your Centres into new Tubeless Rims...!!
www.mullins.com.au/wws-wcp-r-r.asp
1 year 4 months ago #242096
by ashmenz0
Replied by ashmenz0 on topic 8 stud tubeless rims to suit 1973 Denning
Thanks hayseed
That may be an option as well.
Ash
Ash
1 year 4 months ago #242097
Replied by cobbadog on topic 8 stud tubeless rims to suit 1973 Denning
Doing a very rough conversion to Imperial you need 8 (stud) on 5 7/16" PCD (pitch circle diameter) with a 7 7/8" bore. Offset will need to be measured from you original wheels.
Some Jap trucks may have a similar drilling and well worth looking at. Some old time Pommy drillings may also match up but will be Imperial not metric.
1 year 4 months ago - 1 year 4 months ago #242098
The problem There MAY be in the Tyres & not the rims.. How Much Weight was needed on the Old Tyres??
EDIT: i much prefer to get My Steer Tyres Balanced on the Truck. That way whole thing (Tyre, Rim, Hub & Drum) is balanced..
After visiting three Bridgestone dealers I finally got them balanced. The fella who balanced them said the rims took a lot of weight and I should piss them off and put tubeless on.
Last edit: 1 year 4 months ago by hayseed. Reason: added a Bit..
1 year 4 months ago #242117
Sum ting wong there, John. PCD cannot be smaller than bore......
Replied by asw120 on topic 8 stud tubeless rims to suit 1973 Denning
1 year 4 months ago #242121
yeah I did it as a radius so double the number I wrote to get the correct PCD of 10 7/8"
1 year 4 months ago #242123
Replied by PDU on topic 8 stud tubeless rims to suit 1973 Denning
Bit late seeing this thread, but noticing your picture with dimensions Ash and went out to check my Bedford rims: 220 & 275 as per your dimensions, but stud to stud is closer to 105 not 110? :oops: :huh:
As an alternative you might be interested by Bad Chad's way of doing away with the heavy split rims?
www.facebook.com/badchadcustoms/videos/t...el-/744424426764984/
m.facebook.com/badchadcustoms/videos/mak...ls-/655753245614103/
1 year 4 months ago #242133
by ashmenz0
Hi Hayseed
The old tyres needed heaps of weight too. Old weights clipped onto the edge of the rim. The new weights are stuck on the inside of the rim.
My biggest issue is the amount of pressure build up and why this happens? Will it be worse when I'm driving longer distances and in very hot conditions? Makes me feel very uneasy.
1 year 4 months ago - 1 year 4 months ago #242134
by ashmenz0
Hi Jon_d
Their website has a picture of exactly what I'm looking to do. Email sent and fingers crossed.
Thank you very much. You may have just made my year.
Last edit: 1 year 4 months ago by ashmenz0.
Time to create page: 0.512 seconds
