- Thank you received: 3080
farmall m tyres
5 years 3 months ago #198416
Replied by cobbadog on topic farmall m tyres
Tyre sizes.
Imperial tractor tyre sizes were read as ge 13.50 x 32 as being 13.5" profile ( from inside of the bead to the tyre OD ) x 32 = 32" rim.
Radial tyres from memory would be read as the first number being the profile of the tyre then the next number is a percentage of the height to make the width, then the rim size. As an example if a ttyre was 400/50x24 it would have a profile of 400mm and width is 50% of the profile = 200mm and fits a 24" rim.
To get the final all important OD simply multiply the profil by 2 and add the rim diameter.
5 years 3 months ago #198417
by allan
Replied by allan on topic farmall m tyres
Back to front on the profile?? I think the height is a percentage of the width, so in the 2nd example above a 400/50 is 400 mm width, and the height is 200 mm, so 200 x 2 and divided by 25.4 (to get to inches) plus the rim dia of 24" gives overall dia of 39.7"
5 years 3 months ago #198438
Hi Allan, that may well be correct as the radial tractor tyre was not available here when I was in the tyre game. My description was based on passenger car tyres specs.
5 years 3 months ago #198440
Fading memory here.
5 years 3 months ago - 5 years 3 months ago #198442
by allan
For example, when Landrover put wider rims and tyres on the Defender Xtreme wagon they deliberately chose 235R80x16 tyres, as in a pinch out bush you could put a 7.50x16 tyre on the rim and they'd have the same rolling radius.
Width of 235 mm converted to inches (=9.25"), multiplied by 80% (=7.4") to get the height, then double that (top and bottom) and add to 16" (=30.8") and it's almost exactly 7.5" by two plus 16" (=31").
From an engineering design viewpoint it also meant that they didn't have to stuff around with gear, transfer or diff ratios.
Last edit: 5 years 3 months ago by allan.
Time to create page: 0.408 seconds
