Re-power D5N 300
7 years 1 month ago #181248
by Coloze
Re-power D5N 300 was created by Coloze
Keen to know if any members have re-powered D5N 300, prefer diesel enough hp to suitably tow 20 foot caravan.
Any input appreciated
- Thank you received: 4836
7 years 1 month ago #181251
Replied by Mrsmackpaul on topic Re-power D5N 300
Welcome to the forum
I think a lot depends on what you want out of it
If you wanna cruise along at 100 and zoom up and down hills all day towing the van into head winds and maintain a good speed is a lot different than than poking along 80 and dont mind dropping a few cogs on a climb
7 years 1 month ago #181252
by Coloze
Replied by Coloze on topic Re-power D5N 300
Thanks Paul, appreciate your comment, mate I'm 70 think that gives you pretty good idea what I want
7 years 1 month ago #181253
by 600Dodge
Replied by 600Dodge on topic Re-power D5N 300
Don't go diesel, LS with carb conversion if you aren't into electronics.
7 years 1 month ago #181254
by Coloze
Mate appreciate your input, unfortunately don't understand, why not diesel, what is LS, brain a bit slow now days.
Thanks again.
Thanks again.
7 years 1 month ago #181256
by 600Dodge
Diesel is over rated garbage in something the size of the 300. An LS is the same aluminium V8 as found in Holdens from about 1999 on, cheap to buy, plenty of power, light, easy to get parts for, reliable and efficient.
7 years 1 month ago #181257
by Coloze
Thanks heaps, an option to consider, mate had early V8 Holden, pretty sure he's still alive, must catch up and find out his opinion.
Thanks again
Thanks again
7 years 1 month ago #181258
by 600Dodge
Whats in the 300 now? A 245? Ive got a couple of V8 Dodges myself, even a conversion to 318 will be way better than the 245, they are only good for boat anchors.
7 years 1 month ago #181261
by Coloze
245, low miles but needs 'upgrade' of some sort to be reasonable tow vehicle, how do you like the 318 I assume would bolt straight onto current gearbox, worth doing web search see whats available.
Appreciate your input
7 years 1 month ago #181267
Replied by JOHN.K. on topic Re-power D5N 300
You cant beat a late(77-79) Dodge 318 proper truck motor,not a car donk,with the Carter super economy carb.better fuel mileage than many diesels.But,where to find one?Also most have been hotrodded by idiots,and will need a new camshaft,and manifold.Not to mention the original exhaust manifolds.So,the next choice as I see it would be a box Chev small block.Youll have to buy adaptors,unfortunately,pushing up the cost.Regards John.
Time to create page: 0.521 seconds
