- Thank you received: 17
Carbie replacement.
9 years 4 months ago #152890
by AT4 353
she'll be Jake.
Replied by AT4 353 on topic Re: Carbie replacement.
what type of Carter do you have? holley carbies are easier to get parts/ jets and easy to tune compared to Carters. I also have a 465 vac secondary holley carby up for grabs, also a Carter thermoquad and a AVS. Fuel usage would depend on gearing, engine specs, vehicle weight and state of tune e.g. ( compression, timing, spark plugs, air cleaner and of course carby condition.
she'll be Jake.
9 years 4 months ago #152891
by indianman
Replied by indianman on topic Re: Carbie replacement.
G'day I fitted a 500 two brrl Holley to a customers 318 a couple of years ago and he still rates it as the best thing he's ever done ( even better than the A/C ).
He claims it pulls better and gives better fuel eco and also got rid of that annoying flat spot carters are prone to develop. Bought a full reco of fleabay and adaptor plate from repco and we were away.
Jon
Jon
9 years 4 months ago #152892
by AT4114
Replied by AT4114 on topic Re: Carbie replacement.
Hey backyard I swaped out the old factory 2bbl carter on my old 318 CL charger for a 4bbl Holley setup what a transformation it made even the fuel economy improved the 4 bbl realy woke that motor up I think you will be pleased with the conversion should you swap out the 2 bbl did I mention the induction roar
9 years 4 months ago #152893
by kenny-mopar
Replied by kenny-mopar on topic Re: Carbie replacement.
The Holley 600 you will find uses less fuel than the 2bbl Holley 500 (the 500 also has extra large accelerator pumps)
9 years 4 months ago #152894
by AT4114
Spot on kenny never had much luck with the 2bbl Holley carbs economy wise with the mopar small block
9 years 4 months ago #152895
by spc383
Replied by spc383 on topic Re: Carbie replacement.
Oven cleaner on the paint. Aeroguard works well on fresh spraypaint and graffiti.
- Backyard Fixer
9 years 4 months ago #152896
by Backyard Fixer
Replied by Backyard Fixer on topic Re: Carbie replacement.
2 BBL to 4BBL. Do I have to change my intake or will I get away with an adaptor?
- Backyard Fixer
9 years 4 months ago #152897
by Backyard Fixer
Will the 2 1/2 inch stainless stakes get louder?Hey backyard I swaped out the old factory 2bbl carter on my old 318 CL charger for a 4bbl Holley setup what a transformation it made even the fuel economy improved the 4 bbl realy woke that motor up I think you will be pleased with the conversion should you swap out the 2 bbl did I mention the induction roar
9 years 4 months ago #152898
by kenny-mopar
Best to change your intake.. Doubt the exhaust will get louder unless you listen to the sounds of the cobwebs getting blown out
9 years 4 months ago - 9 years 4 months ago #152899
Replied by jon_d on topic Re: Carbie replacement.
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationtry this stuff, Melamine Foam
It's magic for cleaning and polishing things like chrome and stainless.
Last edit: 9 years 4 months ago by jon_d.
