- Thank you received: 1740
1975 Atkinson restoration
JOHN.K. wrote: To me it looks like the lock has been immobilized,common on fleet trucks to stop drivers fiddling and wrecking tyres and diffs.........If you are in doubt,just take the unit off the gearcase,its easy to remove and replace.........
John, I tried the diff lock when I bought the truck (got it bogged) and the DIFF LOCK light comes on and it works, so it hasn't been immobilised. Also, I did pull it apart as a bought 4.11 diffs and I transferred it from my old diff, which is how I worked out how it seems to work. I guess when I get it all back together again I will know if there is a problem. Hopefully there isn't, but was just a bit interested in how this type works. Couldn't find anything on the internet. By the way, the new 4.11 diff had the type you mentioned with a brake type booster which pushes the fork to engage the lock.
jeffo wrote: On Facebook, might be good for some spares?
I know that truck as I bought my first truck from MJ and Bob (Bob has since passed away) about 4 years ago (the Yellow MKII Atkinson with a sleeper).
- Thank you received: 4758
Can be hard to stay enthused if you cant feel your fingers
When I did my Diamond Reo up I kept looking at all the wreckers and managed to find 4 of the 8" ones which I put on the outside of the drive.
