- Thank you received: 20
Turbo Perkins into a A359D Dodge
4 years 11 months ago #201021
by Dazza1949
Turbo Perkins into a A359D Dodge was created by Dazza1949
Hi
I’m back again. A few years ago I restored a A359D Dodge Truck. I’ve never been happy with the original motor, which by the way spent $7000 on an overhaul, so now I’m in the process of fitting a Dot 3 Turbo Perkins 6/354 and a 6 speed Commer box. Once I relearn how to post photos I’ll put some up.
Darryl
Darryl
4 years 11 months ago #201023
Replied by Sarge on topic Turbo Perkins into a A359D Dodge
Welcome back, just wondering what was the motor that chewed up your wallet. :ohmy: and what went wrong with that project???
4 years 11 months ago #201024
Replied by Dave_64 on topic Turbo Perkins into a A359D Dodge
Dazza, don’t forget we want a few words of wisdom to accompany snaps!
4 years 10 months ago #201025
by Dazza1949
Replied by Dazza1949 on topic Turbo Perkins into a A359D Dodge
It was the original motor... Flat head 6. The quote started at about $3500 but they kept extending it and the motor hasn’t performed....very disappointed
4 years 10 months ago - 4 years 10 months ago #201026
by Dazza1949
Last edit: 4 years 10 months ago by Dazza1949. Reason: Replace Heading and add text
4 years 10 months ago #201029
Replied by JOHN.K. on topic Turbo Perkins into a A359D Dodge
i wouldnt expect a 250 sv to have much go..........the same truck used to have the 361 V8 in it.......and they did fly.....had one in CDW,towed a light single axle trailer..........believe it or not,the truck used to deliver and service flagpoles,nothing else.
- Thank you received: 547
4 years 10 months ago #201030
Replied by Blackduck59 on topic Turbo Perkins into a A359D Dodge
looks like you sussed the pic's, easy once you have done it a coupe of times
The following user(s) said Thank You: Dazza1949
4 years 10 months ago #201033
by Dazza1949
The 250 Side Valve 6 will keep up with the traffic up to 60 and I suppose the 3 ton 359 Dodge was set up for around town deliveries but it’s screaming on the highway and hills are not it’s friend. The Perkins will fix the power problem and an overdrive gearbox will fix the lack of speed issue.
4 years 10 months ago #201035
If you want a Commer 5/6sp box,there is a one piece ally housing to match a 6/354 to a commer.....they are a pretty big box,and some come with a #2 sae housing(ex knockers and V8s).......again pretty big for a small truck........looks like your motor does have the #2 housing...............I would use the one piece ,it wont intrude up into the floor so much............did you know one Aussie Dodge did have a Commer box?
Time to create page: 0.574 seconds
