- Thank you received: 888
You will when you're 116, Morris.Morris wrote: Repco sell a product called Hylomar both to brush on, or in a spray can. for applying to head gaskets. I have used the spray can version for the last several heads I have replaced. All many years ago now. Mine were all new gaskets but it should help on good condition used ones.
You have to watch out for that arse-bestos but I am 75 and experts say it takes 40 years for mesothelioma to affect you, so I don't care.
When i am 116, I will get you to help me and if you don't I will haunt you!:ohmy:
Copper wrapped asbestos - Morris and V8Ian?
And axle relocation plates coming along nicely. Perhaps I could even use two bump stops?
Someone out there must have an old M series Bedford chassis they're not using - I need two u-bolts and the bump stops, please, pretty please, beg, beg, grovel . . . :blush:
Next I had the fun of attaching the plates to the springs and aligning the axle onto the locating dowels in the plates. Three holes still need a little bit of finessing with the file but I was still able to snug everything up so it couldn't move.
With this done I loosely refitted the front guard again to see whether the wheel was centred in the wheel arch - the result justifies all my measuring, checking, and re-measuring.
The tyre sticks out about 3/4", but when I have them reset, they'll be back under the guard by the same amount. AND while I was at it I took two pictures to show how they look from the front:
TOO WIDE
NO WAY!
The second one is reminiscent of the old Morris J2 Messenger vans - only worse!? :ohmy: :sick:
I used to have a Commer version of one of these with Buick 15 x 7 inch wheels on the back, three double bus seats in the rear for my five kids (at that time) and room to spare. :blink:
Please note, I still need two M type u-bolts . . . ?
Meanwhile all is in hand with the steering box. The hole spacing for the steering box is three and a half inches, so I may just drill one hole and move it that amount instead of the three inches that the axle has been shunted - hopefully I'll be able to pick that up on the splines?
When you moved your axle did you use two or three u-bolts, and was your bump stop over the axle, or in the original position?
Engine had 7 spark plugs in it. Piston is corroded right through.
Back to your regular programme:
